losi 1/5 scale
Last I checked, the Losi 1/5th scale trucks have gasoline fueled spark ignition engines. Unless you have reliable provenance, I'd get a Walbro carb rebuild kit (K20wat) and a new spark plug. NGK seems to be the go-to brand though the heat range and size you'll need to cross reference. Rebuild the carb after carefully cleaning it and replace the spark plug. Fire it up and see what happens.
