Kit fix
Kit fix
I am wondering if anybody knows how to patch holes up on the body or if I have to replace the body. I bought a Camaro police car and the light bar was placed too far forward so I relocated it into a more accurate position. Now I have 4 holes where the screws held the light bar in. Any suggestions? The top is white.
Oof, well I guess it depends on how nice you want it too look. You might be able to find a plastic welding kit and fill the holes. You might get some abs plastic, as the body is likely abs, and use abs glue. Cut pieces and stick them to the underside and fill the dips that are left. You could do it quick and dirty and just use stickers.
hi steelrfan , well you can cut a piece of clear plastic paint the plastic white let it dry than go buy some shoegoo at walmart or hardware store than glue it in on the underside of roof the stuff works great
to fix lexan bodies for 1/8 scale racing when ii gets ripped , a plastic pepsi or coke bottle will work too , hope i helped ok mugey
If you just do not want holes in the roof why not just get screws or bolts to fill in the holes with nuts underneath holding them in as a filler. Paint the bolt or screw heads white to look a little better.
