What are these parts?
Hi,
I have Thunder Tiger MT4-G3.
It runs great except the fact that every couple of runs a different pin is gone.
After few times it happened, I noticed that there is a ring/clip that covers the pin and prevent it from sneaking out.
The problem is that the clip/ring is also gone, but I couldn't find where can I buy it and what its name.
The clip/ring has different sizes. However, they fit some Thunder Tiger replacement parts kits like:
PD05-0017 , PD05-0044
For example:
goo.gl/images/NJb38q
nitrohobbies.com/PD05-0017/
For example:
If I'm reading the post right, I bet you could use Associated #89106 CVA Pin Retainer. Those clips/pin retainers need a drop of CA glue to help assure that the clip will not move. If you don't use glue, the vibration will work those clips/CVA pin retainers around...letting loose the CVA pin during one's RCing endeavours. Does the CVA joint coupler have a threaded hole for a set screw? I have used the set screw, and the pin retainer for double reassurance purposes.
