official smartech buggy thread
#4101
IL
RE: official smartech buggy thread
2 1/2 turns out on the high speed needle and i belive 1 turn out on the low speed needle, should be posted somewhere on this thread but i cant swear to it
#4104
NY
how do you know the engine is worn out ?
I was running in sand and then the engine just quite, temp was 240F.
I tried to run again, but it would not run... i took the engine cleaned it out, but still the same problem
replaced glow plug.. no change..
what should i look for, if the engine is worn out..
this is only the 15th time the engine has worked ...
Cheers
#4105
u know the engine is worn out by it having low compression. if you pull it over slow does it turn over without feeling any resistence? also when u thghtened the head bolts did u make sure to go diagonal? if u just went to each one in a clockwise or counter clockwise pattern that could b a problem cuz the head my b slightly off alowing a compression leak
#4108
please i have the same buggy but it came in pieces i need the breakdown of the trans so i can put it together do you have a manual mail me a copy of the breakdown if you have i dont think ill get it together without it
