Gas on drive way
ON, CANADA
RE: Gas on drive way
Does that actually work? I've tryed CRL, VIM, Goof Off 2 nothing works. My mom won't get a power washer, they are like 300$.
ORIGINAL: frozen
TX
You can buy absorbants that will absorb the gas. You can also use kitty litter. Put the kitty litter on the spill and wait a day or two, then sweep it up. The one draw back is that stray cats will think that your drive is their litter box.
AL
Simple Green, put it on full strength and let it stand for a few minutes. Scrub it with a stiff brush and hot water then rinse it off with plenty of water. Should do the trick.
CA
all else fails light it up on fire
we have a little pyro in us
ORIGINAL: iliketobreakthings
how else do you put it out? fire extinquisher? or just let it burn off
or use sand/dirt
