Mamba Max ESC and Castlelink Problem! :X
CA
Sorry if it's a noob repeat question.. But I'm having quite a problem over here.
I've installed all my drivers, and Castle Link correctly, I believe.
The problem is:
When my Mamba Max ESC (I'll just call it the MM right now), it just flashes Green and Red.
I attempt to do something on Castle Link, but it just beeps at me, as if it's not selected. Task bar is selected, everything.
It detects my MM, or so says the Castle Link. Any ideas?
The problem is:
LA
RE: Mamba Max ESC and Castlelink Problem! :X
Make sure the battery is unplugged and the switch on the ESC is set to on. Also make sure you plug in the wire in the correct way. I also plug in the ESC after I open the castle link software.
ND
ORIGINAL: rawfuls
Thanks, everything is checked.
Should I disconnect the motor?
ND
Do you use the castle link or do you connect directly to the mamba max esc?? If you connect directly to the MM try disconnecting it from the USB cable and see if you still get a beep from trying to use the program. If you don't get a beep then their is a good chance your MM might be bad, I had the same problem with a BEC when trying to program it I would just get a beep from the computer.
http://www.castlecreations.com/produ...stle_link.html
ND
Can you click on the Update and Check for update buttons on the top or do you just get a beep then to? If you get a beep then I would uninstall the program and reinstall it from there web site.
http://www.castlecreations.com/downloads.html
CA
Running XP Pro SP3.
Just upgraded to SP3, wanna see how much better it is.
So far, I'm okay... Don't notice any large improvement though. Lame microsoft.
CA
I was already uninstalling while you told me to uninstall, and reinstall. Fortunately, it worked! Woohoo, time to read the manual. >_>
ND
I didn't notice a difference with SP3 either just when I switched from media edition back to standard XP I can't stand media edition.
Any luck with the install and MM now? Don't forget to do a restart after all this fun your having.
CA
Hmm, after thinking about it, I have 3 hdds.
1 External (Most of the time off, my backup)
2 Internals (120 GB C: and D
80GB G:
I installed the Castlelink Program on my partitioned 120GB disk, drive D, but when reinstalled, I installed it onto my C drive, my OS partition.
Could this matter?
80GB G:
Could this matter?
ND
Yeah like I'm going to know that one so I'll give it a shoot in the dark yep that had to be your problem... LOL I have no idea if that was the problem or not.
Hi, can anybody clarify that mamba max playing sound/tone when it connected with castle link?
also do the mamba always flashing the red and pale green led when it connected?
LA
ORIGINAL: Papa Jay
yup, no tone.
I just clarify this on rctech
I've pretty bad crash before, just want to make sure everything is okay, thanks.
