newb qestion... sorry????
ok well thanks in adavnce for looking .....
ok i was looking... just at Rc stuff w/e when i notice some sites say glow starter and some say glow plug ... are they the same thing ... if soo which one do i need to buy more of .... i really havent seen a glow plug by its self how do you guys pay... do you guys just pick them up at your local hobby store ...Not hobby lobby or w/e like a actual hobbie store can i pick up nitro fuel there too?
th th thank you .... its expensive at first but i gess it will pay off
peace .. happy thanksgiving everybody!!!!!!!!!!!!!!
CA
RE: newb qestion... sorry????
there both need a glow plug is something that helps start the engine a glow starter is something you put on the plug to heat so you can start the engine, a glow plug normally last 2-4 gallons of fuel so you should buy more plugs you only need 1 starter with a charger
ok
thanks
so if the thing that comes with the starter kit is the starter t
then what a glow blug .... is it on the car or in the starter??
thanks once again
thanks
thanks once again
the glow plug is partof the engine.
The glow starter it what you attach to the glow plug - the glow starter / warmer will be in ur starter kit. and the glow plug will come with ur engine
PA
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB27&P=ML]This[/link] is a glow plug.. (usually comes installed in engine)
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXSF52&P=ML]This[/link] is a glow starter (usually uou have to purchase this seperate)
Both the Glow plug and glow starter (also known as glow driver) are needed to start your r/c car.
--evader
Happy Thanksgiving Everyone!
--evader
AZ
a glow plug is just a lot like a sparkplug only it needs an external power source (glow igniter) to ignite it that is taken off once the engine is running.
thanks alot ..... now i get it all .... im 13 so i have to get everything just right to get how it works ..... now i get it and just last night i was on google inmagies see what it is and figured it out...
THANKSSSSS !!!!!!!!!!!!1
