15 %vs%20
OH
15 %vs%20
A LHS sells 15%nitro. He says it runs cooler without any power loss. I don't know enough to say any thing. I don't know the name of it but its not a home brew.Do any of you run 15%.and would 5% less nitro make that much of a difference.
AL
RE: 15 %vs%20
ORIGINAL: dpb73
Its more than likely Morgans Omega is its 15%. Great fuel in my opinion. You will notice a slight drop in power and will have to retune. As far as running cooler, thats dead wrong. Up to a point, more nitro will actually cause cooler temps. The reason..... higher nitro %'s allow for a richer needle setting. Richer needle setting = more fuel. Alcohol is the main ingredient in our fuel and it actually burns cool.
Less nitro you have to lean the engine out in order to make any power.... lean is mean but causes higher temps.
RE: 15 %vs%20
ORIGINAL: bigbadbowtie
So to wrap up, same temps/longevity, less power.
I would personally stick with fuel designed for cars in a 20% blend. That is what most engines are designed to run and they do run quite well with it.
RE: 15 %vs%20
Why are we jumping to conclusions about the brand of the 15% fuel? You may be right about it being Omega(which I use in my planes), but not necessarily. The two LHS around here each sell several blends of car fuel in 15% nitro and 10% nitro. Duratrax Red alert and Powermaster are two that spring to mind. Either way, the information about re-tuning slightly for varying nitro content referenced in the previous posts if correct. Conservatively tuned, you will notice slightly less power on 15% nitro, probably not enough to really miss.
