RS4 3 Problems
RS4 3 Problems
i have a hpi nitro rs4 3 and wen i try to go full throttle the car turns to one side and i carnt figure out u can anyone help.....and how do u refil shock oil? thnx
RE: RS4 3 Problems
1. do you have the servos in the right place (throttle/steering switched)
2. make sure your wheels are lined up straight
3. unscrew the cap and add it, look in your manual
RE: RS4 3 Problems
make shure you have the same amount of spacers on the shock ( spring compresion)
and make sure the springs are not damaged and are the same size.
maybe your bearings went out, I re-dip mine in lubricant
