Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Reload this Page >
******Pictures of your Himoto's and OTHER RIDES!!!******
Old 02-07-2009, 09:56 PM
  #651
kuppler
kuppler's Avatar
Default RE: ******Pictures of your Himoto's and OTHER RIDES!!!******
ORIGINAL: airoscar
i'm sorta having fun fixing it and breaking it again,
Its part of the HOBBY bro........ how does that camera Work???? i have a mini spy camera and it Records onto a 4gig internal memory. but i dont see how urs would save video...
by the way.. have you tryed doing PLASTIC WELDING?????? Works like a CHARM!!!!!
Old 02-07-2009, 10:29 PM
  #652
airoscar
this one im using is a 2.4GHz wireless camera so it only needs a 9 volt pwoer source and it will just transmit everything to a receiver that i have connected to my tv; i actually have a couple cameras like this even have infrared night vision but not as tiny and light as this one . im getting an old tv tuner from a friend who does not need it anymore, so that i can record the video straight to my computer, i think its kinda cool.
plastic welding? i only heard of cold weld where you mix this blue stuff with red stuff and it welds even metal.
Old 02-07-2009, 10:47 PM
  #653
kuppler
kuppler's Avatar
check out this link for the Plastic welding...
http://www.rcuniverse.com/forum/fb.asp?m=8448005
Old 02-07-2009, 10:57 PM
  #654
airoscar
OH that, lol, yeah i have done that, but i dont rely on those too much they often break again too easy
Old 02-08-2009, 12:02 AM
  #655
Redharris
Redharris's Avatar
ORIGINAL: airoscar
That depends where the Break is, and how skillfully you do the repair......
A while back, running my Viper, I ripped the lower rear arm CLEAN off the hinge pin.
I was right in the middle of one of the contests and couldn't wait for parts.
I performed the Plastic Weld technique and it worked like a Charm.....
In Fact, it worked so well that I FORGOT all about the Break, for about 3 weeks, till it finally Failed.....
By then, I had the parts on my bench, ready to go.....
Airoscar ....
Your break IS in a bad spot and I can see that it would not be a good spot to do a plastic weld.....
Old 02-12-2009, 04:00 PM
  #656
rc-psycho
this is a stadium truck we just finish painting
Old 02-12-2009, 04:03 PM
  #657
rc-psycho
another pic
Old 02-12-2009, 04:06 PM
  #658
rc-psycho
here it is i donot think last 1 worked
Old 02-12-2009, 04:08 PM
  #659
Swamp3r
Swamp3r's Avatar
Looks good man
Old 02-12-2009, 06:39 PM
  #660
rc-psycho
thanx bro just a lil different then factory stuff
Old 02-12-2009, 07:51 PM
  #661
DMCB
Can anybody tell me why is the pipe leaking?
ID:	1133953   Click image for larger version
Old 02-12-2009, 08:17 PM
  #662
airoscar
ORIGINAL: rc-psycho
this is SICK! that flame is fascinating.
and oh eddie, my brushless doesnt run for 30 minutes on two 6 cells, my bad; it bashes for about 15 min max before the ESC starts to cut, i guess if i have two 4000 batteries in there it might go to 30 min run time.
i put one shim (the stock himoto shim) in each differential and it runs really good now. i think that one thread about differential gear mesh should be made into a standard new vehicle checking procedure.
Edit: Eddie i cant find the part list for my emxt-1 on your site?
Old 02-12-2009, 08:59 PM
  #663
rc-psycho
thanx guys ..im going to paint my PYTHON next
Old 02-12-2009, 09:19 PM
  #664
ehroof
Hi Oscar,
Try typing in the part number in the search, if it doesnt come up, drop me an email with the part numbers and I will get back to you with the prices.
Old 02-12-2009, 09:41 PM
  #665
airoscar
hey eddie, there seems to be something connection thing with your website at the moment, at least it's not loading for me, i duno if its the site or my connection.
Old 02-12-2009, 09:52 PM
  #666
ehroof
dont know, will have to find out what is going on.
Old 02-12-2009, 10:00 PM
  #667
airoscar
its working now..
Old 02-13-2009, 03:09 PM
  #668
bluecaka69
bluecaka69's Avatar
Here a sick ride for the STEELERS FANS
http://www.rcuniverse.com/forum/m_84...tm.htm#8473021
Old 02-13-2009, 04:31 PM
  #669
DMCB
So, can anybody help me?
Old 02-13-2009, 09:41 PM
  #670
ehroof
i just looked back and saw your post. Check the connection between the header and pipe (rubber) and the connection on the pipe between the 2 pieces, maybe its loose and the screws need to be tightned up.
Old 02-13-2009, 09:55 PM
  #671
DMCB
I don't know what's wrong. I checked everything and it looks fine.
Old 02-13-2009, 09:58 PM
  #672
ehroof
its hard to tell from those pics but I would suggest taking off the pipe, cleaning it off. Blow into one of the ends, Make sure the there 2 are plugged (the small line that goes to the tank) and see if there is a leak.
Old 02-13-2009, 10:00 PM
  #673
DMCB
Already tried that, but I'll do it again
Old 02-13-2009, 10:01 PM
  #674
ehroof
then check the rubber connector betwen the pipe and the header. Anything on the engine? take a picture from the top.
Old 02-14-2009, 11:03 AM
  #675
DMCB
Top of the engine or pipe?
