2 speed gear
2 speed gear
question i got one of the older hsp sonic rc cars now got her running couldn't finish tuning it seems it don't go anywhere the gears seems the pin poped out and not suer what i can use any help it's a moderate gear set part number 02076
RE: 2 speed gear
just drop me a pm or an email bro if you want the trans but before your do, does the clutch bell spin and the spur gears? maybe your drive cups are loose?
RE: 2 speed gear
if everything is tight and the spur and clutchbell are spinning then i dont really know what to say. are the front and rear dog bones spinning, the ones from the trans to the front and rear diffs?
RE: 2 speed gear
no didn't take apart the only thing i see is that the big gear in front just spins and the little gear behind won't engage i don't know what else to check
RE: 2 speed gear
sounds like either the one way is shot, the pin or the gear is shot, the 2 gears should turn no matter what, my opinion and what i do is put a single speed trans and change the clutch bell. I like the single speeds on offroads, especially the other style rc's.
RE: 2 speed gear
the pin is in the smaller gear but it don't connect to the big gear ans there is no little hole for the pin to go through the big gear
RE: 2 speed gear
i didn't i looked between them there is some play between the gears.Car work fine when i was try to get her tuned then it just stoped moving.So i just order a new trans and go from there.I'll pop the order in tomorrow
