Duratrax Onyx chargers
Each Onyx charger includes all of the features you want, and none that you don't.
Anyone else have one of these yet?
I've come to notice that my 230 has no discharge feature [:@]
CA
RE: Duratrax Onyx chargers
Yes, I have 1. It charges 123, lipo, nicad, nimh, and li-ion batteries and charges up to 7 amps AC or DC. You dont need to discharge if your runing nimh packs.
not entirely true. NiMH cells develop a memory, just nowhere near as fast as the Nicd chemistry does.
Its a problem we also have in our arcade games. We shut them all off at night... but they don't have hard-drives to save stats and high scores. So, in order to save money for both the manufacturers and us, the arcade manufacturers use NiMH cells inside the games. Since they develop a memory over time, we have to replace the packs, or each individual cell so that the games can store the memory all night.
UPDATE:
also noticed it has no balancer... charger is goin back to tower!
UPDATE:
ORIGINAL: Kemo
UPDATE:
UPDATE:
you have to add a balancer, most chargers dont have one[&:]
see thats why I was fooled into buying it. Duratrax advertised it as "ready to use" after charging (lipo).
Next charger will be one of those I keep gettin emails about distributing for, all of them have built in balancers, and they also have a discharge capability!
CA
Then if you dont like that charger show me a AC/DC charger that is $80 and can charge lipo, a123, nicad, nimh, li-ion and can charge up to 7 amps ac or dc, trinckle charges, has a discharger and a balancer. there isnt one!!!!!
there is, but they come from china and minimum order is 50 of them at $50 They come from the same factory the venom ones do
however, they are floating all over ebay... no ebay links allowed though
Also Nimh cells will go into cell reversal if you discharge them to the point of no return. Slight memory or not, you need to be careful if you do discharge them.
CA
and with that charger it doesnt charge a123 or li-ion and I think it is only DC. Plus no trickle charge and a couple other things. Plus, I got my charger for $90 and that is going for $111.
There are AC adapters for these chargers, and yes they charge almost every sort of Li- variation for r/c. The A8 does 1-8 cells, whereas the A6 does 1-6 cells.
Warranty varies depending on which distributor you buy from. Some are 90 day, some are lifetime.
ORIGINAL: Kemo
Also, if you think you can buy something from china on ebay with a "lifetime warranty", you are right... if you think you can actualy use the warranty though, well I have a bridge to sell you.. CHEAP!! (it is from china though....)
As for this "great" charger from china... if the discharge feature is is important to you, look at the stats... 1 amp (or 5 watts, whichever is lower) discharge MAX... you are going to discharge a 5000mah battery at 1 amp? thats 5 hours... fun...
i dont know much about eletric stuff. i was looking at a onyx 200 just to charge my roto starter battery, rx pack and a tx pack which are nicd and nimh batterys. would this charger be ok for that???. do i need a balancer and a dechager for nicd and nimh??
