Need info on Traxxas Slash & Slayer wheel specs!
RE: Need info on Traxxas Slash & Slayer wheel specs!
From what I understand is the Slayer doesn't use your typical 2.2 tire. Rim/ tire look 2.2 from the outside but the rim is larger on the inside bead to clear the Revo hub. Rim is more of a cone shape as appose to a cylidrical shape.......if this helps you at all.
I'd ask you what you have going on but I have a feeling you are in secret mode.
Ok, Thanks,
I noticed that too on the traxxas website exploded veiws, and they sell them pre-assembled tire&wheel.
I think I'll be looking for 2 pairs of Slash rear wheels instead.
I think they look good on a scale crawler.
they don't make the wheels that come stock on the slash seporat, they are the "slayer" style with the larger inner part and 12mm hexes. as of right now, no one makes tires for the slash rims, proline does make beadlocks to use there own tires
wheels are
Dual profile (2.2" outer, 3.0" inner)
tires are
Outer Diameter: 4.3" (109mm)
inner Diameter: 2.2"-3.0" (0.09mm-76mm)
Width: 1.87" (47.5mm
http://www3.towerhobbies.com/cgi-bin...=SLASH+++wheel
wheels are
tires are
WI
ORIGINAL: kantfunkshin
So does anyone know which other brands of wheels and tires that would fit the Slayer besides the factory ones? Thx
