Solder-It Silver Bearing Solder Paste??
ON, CANADA
Anybody ever heard or used this stuff? Found it at Princess Auto last night and picked up a tube. It's a paste and i believe has flux mixed into it......supposed to have "superior conductivity" and have 5 times the strength of a normal solder. You basically squeeze the paste onto your area to be soldered and just heat it up with a lighter and it hardens. I tried it out last night and definitely gave me a sturdy silver looking soldered joint. I'm just wondering if it's as good conductivity wise as they say it is.
I suck at soldering (need more practice), and this stuff seems to be an easier method. Although I know shortcuts usually don't end up working as well as they were intended.
ON, CANADA
RE: Solder-It Silver Bearing Solder Paste??
http://www.solder-it.com/solderpaste.asp
Even noticed Lowe's sells the stuff. My main concern is if it holds up to high current rc applications?
