Replacing wheel bearings
OK
Most of us know how hard loamy/dry tracks can be on our outer wheel bearing (1/8 buggy and truggy). It seems like after a day of racing the rear outer bearings will almost always need to be replaced. Cleaning them out with WD40 and re-oiling wont get them rolling smooth without that notchy feel to them while in your hands. How often are the club racers out there replacing your bearings? If they're not smooth as butter they're tossed, or if they still roll with the wheel not wobbling do you keep using them? Or where is the middle ground?
RE: Replacing wheel bearings
Did you try taking them out and soaking them in a bowl of wd40? or just spray it on?
I always let mine soak that usually removes most of the crap at the bottom of the bowl
Instead of WD40, try lacquer thinner....I've had bearings last years in my dirt oval cars cleaning them by soaking in thinner, then lubing them with a few drops of dry lube....
SD
I use the laquer thinner trick myself. I took a used small coffie can, built a little basket that sits about a half inch off the bottom and let them soak over night, dry for about an hour then soak them in Marvels Mystery oil. I do the cleaning thing once a week and they get replaced once per season.
IL
Myself, I blast the bearings with auto brake cleaner(man, I love that stuff) and blow the cleaner off with compressed air. Then I re lube them with grease or oil(depending on the application). Makes old gritty bearing roll like new.
OK
I try out some of those tricks, would be really nice to have bearings that I don't need to replace every other race day.
