HSP warhead doesnt change gear after taking it apart
hi my HSP atomic warhead doesnt change gear. I put a new spur gear in the gear box and i put the spring inside the 2 way clutch but it still wont change gear
RE: HSP warhead doesnt change gear after taking it apart
it maybe be set wrong, you have to tighten it snug, not crazy tight, then turn counter clockwise 1 full turn and try it, if not do another 1/2 turn and try again, keep doing it until it shifts. Just remember that clockwise makes it shift at higher rpm's and counter clockwise makes it shift at lower rpm's.
and just to be sure could u send me a pic of what thread hole the spring goes into in the 2 way clutch
ok ive seen the ball put the spring and grub screw and must of put it in to tight. Loosening it up now tell u results soon
