NTC3 vs Serpent 705
NC
NTC3 vs Serpent 705
The question is-which would you get? If you got the NTC3 kit and
got a .12 race engine (you put the engine in that you would
recomend for a decent price a good one and post it). or you
got the Serpent 705 with the engine it recomends and some
radio gear that totals around $750. if you go the NTC3 and put
some serious stuff into it to just totally deck out the NTC3 for a
total of $750, would this NTC3 smoke the Serpent? i am trying to
stay around the $700 range. I am sorry if i confused you, i just
cant think of how to put this into words. Maybe if the NTC3 had
the hop-ups to equal the price of the serpent, which would win?
NC
NTC3 vs Serpent 705
the engines i am looking at are the team orion .12's (wasp) and the o.s. .12 tr (p)-t turbo head. this is a link to a towerhobbies page that has all of these engines on it http://www.towerhobbies.com/listings/cat-cat-g.html
look at the first 2 engines and go down to the o.s. .12 tr's
thanks
thanks
VA
NTC3 vs Serpent 705
orions wasp are TRASH they suck in power both HP and tourq but are redicoulsy over priced stick to OS there a quality product that will last if taken care of
NTC3 vs Serpent 705
i would take the 705 anyday because i have one and a impulse.i chose it because my cousin has a ntc3 with a .12 sirio engine into it and a lot of hopups and still smokin him on the track.and we're both equally matcthed on driving. on my 705 i have a .12 re novamega engine in it with no hopups at all except for gearing.the handling is just off the hook on this car if you set it up right at the track
NTC3 vs Serpent 705
Most of the people would say that the NTC3 is better because most of them own it. I would personally go for the 705.. I just like the design of it better..
Driver
Make your decision on parts availability, cost and things of this nature. Once you have done your homework, then you will know which car is best for you.
The fastest car on the market wont make YOU a better driver, if there is a really good driver at your track or parking lot you will never catch him until you learn how to drive. Does not matter what engine you use or car.
Most good drivers can perform on the same level no matter what brand they are driving.
Good luck
Dbow
Good luck
Dbow
NTC3 vs Serpent 705
I have a NTC3 - with lots of hop ups. I love the car. Very nice and now that I put all the hop ups, it is very fast.
Go for the Serpent - You will be much happier.
NTC3 vs Serpent 705
705 is hard to setup, it's a really good car but if you are not an expert...
NTC3 is easier to setup, and also is faster, and you don't need to be an expert to go fast.
I own an NTC3 with a sirio engine and y go faster than a lot so serpents in my local racetrack.
Here in Spain serpent is the brand with more cars on the competitions, so is the car that most people buy, but after observing them....the 705 is not really good, the centax 2 breaks (the axial bearing doesn't last), chassis isn't as rigid as it was on impulse pro...
The NTC3 also has some problems, for example diff boxes are really bad, you must fix them adding to big screws to hold the shock tower, and also you must change the input shaft for one in aluminum, but this problems are not as had to solve as the one with the centax of the 705.
go ntc-3
Hey bud.......call Mark here in Ga. over at Primetime Hobby And Speedway...he has Serpent with a lot of brand new parts for sale.Also ask him what he thinks about the two..........he will tell you to get the tc-3 instead of the serpent....heres there number 706-625-9037...come race with us if you get the chance....tell him Mike McDaniel sent ya
NTC3 vs Serpent 705
the sirio outlaw is an awesome engine i got 1 today and broke it in it it beat the mt12 in a drag really great engine about 1.5 hp that dont mean crap thuoght if u want the best though get the pixi outlaw all three all great engines thought
NC
NTC3 vs Serpent 705
what would be best? getting the rear exaust engine or the side? I have a starter-box, but the rubber thing that turns the flywheel is set up for a car with the flywheel straight instead of sideways. i use this starter box to start my traxxas rustler. would this starter box work with the NTC3 kit?
NC
NTC3 vs Serpent 705
and if the starter box does not work will this? http://www2.towerhobbies.com/cgi-bin...?&I=LXL396&P=7 with this? http://www2.towerhobbies.com/cgi-bin...?&I=LXL402&P=7
NTC3 vs Serpent 705
my cousin has the same problem with the starter box but the best way to use it without buying a new one is just turn the car sideways to start it.thats how my cousin always does it and the one from tower hobbies it works but be careful because the car or the starter can kick back at you.because i have one and it launched my car a couple of feet because i wasn't holding the car tight enough!
NC
NTC3 vs Serpent 705
and i was thinking of that trinity, but thats just TOO MUCH $$$!
if i got that how much would that cost me all together? like $1000?
NTC3 vs Serpent 705
Originally posted by spazzyfry123
does that work?
wat kind of starter box does he have? i have one by ofna
does that work?
NC
NTC3 vs Serpent 705
thanks pnony, an which would be better the rear or the side? and what do the racers use the rear or the side? if its the rear im looking at the http://www2.towerhobbies.com/cgi-bin...?&I=LXCNA3&P=0 cause ive heard that the orions are junk. i think whoever said that is in this thread actually.
NC
NTC3 vs Serpent 705
another thing, what is the legal racing engine size? .12 or .15? or are both fine? and can someone give me a list of some of the legal engines?
NTC3 vs Serpent 705
a legal racing engine is a .12 non turbo plug but it can be modified and they consider .15 as a big block so you can't use that on 200mm races but i would go for a rear exhaust.i have a .15 novamega in my serpent impulse that i recently broke in and i found out that you can't race it so i'm just using it for bashing now but this engine is way overpowered and i think they said the car should hit almost 90mph
NTC3 vs Serpent 705
VA
NTC3 vs Serpent 705
usually on the engines info it will say ROAR legal or OUTLAW roar legal is race legal but alot of street racing clubs dont enforce the engine rule alot unless your in a organized and sancationed event wich not many clubs have check out the place youll be racing and ask about it before you buy just to b shure
NTC3 vs Serpent 705
Well, Since I own a Serpnet impulse pro, and my friend has a NTC3, i can say that right now my serpent kills it anytime... Well, maby because it has o.s. engine with only .8 hp... Maby with equal engines there will be competition, but imho serpent is alot better in turns... A drawback with ntc3 is also the fact that it's fuel tank is posisioned the way that when it get's empty the car get's out of balance. Tho the NTC3 is lighter and CG is lower than in serpent I still find that serpent is alot quicer in turns (don't ask).
If you want a serious racer than i'd go with serpent. If you want to drive any place other than track, where might be some small stones than I'd say go with ANY shaft driven car... I'm keen to test OFNA's LD3... Seems like a good car...
oh, and as for these problems with centax clutch like one guy above mentioned... Owning a centax cluch is'nt a problem... it's a priveledge...
Hope this nonsence has helped you decide
