cleaning my r/c
cleaning my r/c
im really cheap, is there a cheaper way to clean my car than buying that nitro cleaner everyweek??? is brake cleaner the samething or carb cleaner that i can buy at kragen for only $2.95?
cleaning my r/c
break cleaner should be stronger than carb cleaner if anything.
You might wanna check out this thread in the monster trucks forum.. talkin about the exact same thing!:
http://www.rcuniverse.com/showthread...95&forumid=216
ramm
ramm
IN,
cleaning my r/c
Just clean it with a spray bottle filled with denatured alcohol. It's probably the least expensive way to do it (other than removing the electronics and hosing it down)
cleaning my r/c
Simple Green and a tooth brush and some running water.Just take off the engine and electronics,spray the chassis down and rinse it off in the sink.Use the toothbrush for the caked on stuff and then dry it all off and oil the bearings.Been doing it this way for a few months now and it's allot easier/cheaper/faster than anything else i've tried.
cleaning my r/c
Originally posted by migueloo
what´s the water percentage on it? can you just pour it down on the car?
