***OFFICIAL VEGA8 XB 1/8 BRUSHLESS BUGGY THREAD***
OH
RE: ***OFFICIAL VEGA8 XB 1/8 BRUSHLESS BUGGY THREAD***
What voltage does the ESC provide to the motor cooling fan plug? Will it be whatever voltage the batteries provide? If I use (2) 2S lipos in series for 14.8V (i.e. like a 4S like Joacim did), will the fan get 14.8V. Looking around on ebay, I see 5V fans (7.2V max) and 12V fans (15V max).
OH
well, I walked through the programming of the ESC using the SET button and LEDs - it was a little tricky, but it worked like a charm once I got it figured out - and the manual was right on - I adjusted the low voltage cutoff up to 3.4V to better protect the lipos and reduced the initial acceleration a bit to stop the tires from always breaking loose and lengthen the battery life a bit
#31
OH
well I had a chance to try out the new parameters in the ESC - I had increased the low voltage cutoff from 3.0 to 3.4 because I had an issue with one of my packs getting too low on voltage - strangely enough, with the new setting, it ran the pack voltage even lower, lower than it ever had before - and it was not the pack that had gone low before, so it was not due to a problematic pack - I am going to try and set up a DC power supply to connect to the ESC and see if I can adjust the power supply voltage down until the low voltage cutoff activates - maybe that way I can verify the ESC settings and figure out what is going on
#32
CA
you can always get a vot alarm for the lipos. i have 2 of them and they work good. when the volts get to 3.4 it sets the alarm off.
#34
these are the ones i use, cheap price for some insurance and testing purposes:
http://cgi.ebay.com/LED-2s-6s-Lipo-B...item2308841aa5
http://cgi.ebay.com/7-4V-11-1V-RC-Li...item5d29fb4054
#37
CA
found a check for $2.47 shipped.....
[link=http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280433999642&ru=http%3A%2F%2Fshop.ebay.com%3A80%2F%3F_from%3DR4 0%26_trksid%3Dp4712.m570.l1313%26_nkw%3D2804339996 42%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1]CLICK HERE TO SEE[/link]
#39
OH
how long should you store lipos after charging before you need to put them at a storage voltage? or is that necessary? I have heard about discharging them to a lower-than-full voltage for longer storage - do you do that?
#40
nope, i just let them sit after i fully balance charge them...... have had no issues to date and using the same pack for 3 years
#41
Let me know how you make out. I got my buggy to do wheel stands on the rear wing. But I cant open the throttle the whole way with my 4s 40c 5000mAh Trunigy battery. I will be posting a video of what it is doing when I ever get my spare parts I need. They should be on the way. Secondly...... When are the programming components hitting US soil??
#42
OH
i just made a wiring harness to connect the 2 lipos in series for 4S and I picked up a 10t and 12t pinion to gear down a bit but have not tried them yet
#45
OH
divide the mAh of the pack by 1000 and multiply by the C rate - that gives you the max amps the pack can deliver - for example, a 5000 mAh 30C pack can deliver 150 amps - if our ESC is 80A, then a 5000 mAh 20C would be enough since it could deliver 100A - from what I have been reading, it is a good idea to have a little more available from the pack than the ESC max
