OS RZV Engine Question??
Im most likley going to buy a that engine tommarow for $150 bux. It has a gallon through it, and from what ive seen of it it runs great. I just wanted to know from all the OS RZV owners how long can this engine last and when should i rebuild it?
thanks guys!
thanks guys!
MD,
Well, it is a great engine. Life of the piston and sleeve depends on usage. I would say that running it using 30% and not exceeding 250 deg (which means running just right, not too lean and not rich) the engine quite possibly would last about 6-7 gallons making good power. After u go thru 6 gallons I would get the p/s squeezed by osrocket and then you should be able to run the engine again for another 6-7 gallons.
Wow, thats awsome! Its in a good condition, and was just used to race. It had a few 45 min mains at some national races! Wow, thats going to be great, he might of run 20% but im not sure.
thanks
thanks
MD,
If the engine was used during 45 min mains I would open the engine up and inspect all the components. Make sure the piston does not goes all the way thru the sleeve when it is out of the case. No chips or scratches on both the piston and sleeve. Make sure the conrod is in good condition. Look for metal particles from the rear bearing. If the components look good then I would get it squeezed so you have a brand new engine fo almost half price
When they say squeeze.. they mean pinching the sleeve to fit the head.
This is something that people with some fine machinery do. They arent talking about "squeezing" some extra life out of it.
I hope...lol
Ram
I hope...lol
Ram
MD,
P/s squeeze by osrocket goes for about $30. A new set will run around $130. Go to ebay and do a search by seller. Type in osrocket. I have yet to hear something negative about his work.
As far as top speed goes it is kinda hard or almost impossible to determine. It all depends on gearing. As far as rpm goes then I think it is 40000 max rpm and max hp is 2.4 @ 32000.
