Will these tires fit on...
these tires? I am looking for some street tires and wheels for my RedCat Volcano S30.
Tires -http://www3.towerhobbies.com/cgi-bin...LXNTK7&P=0 Wheels - http://www3.towerhobbies.com/cgi-bin...LXYJV0&P=0 Thanks for the help!!!<br type="_moz" /> |
RE: Will these tires fit on...
No. Those tires are 2.0". The rims you posted are 2.2".
That is called being sleepy.... Back to the drawing board. :)
Just for confirmation. These will work???<div>
</div><div>Wheel - http://www3.towerhobbies.com/cgi-bin...LXYJV0&P=0</div><div> </div><div>Tire - http://www3.towerhobbies.com/cgi-bin...LXFBV7&P=0</div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div> |
ORIGINAL: blusls Just for confirmation. These will work???<div> </div><div>Wheel - http://www3.towerhobbies.com/cgi-bin...?&I=LXYJV0&P=0</div><div> </div><div>Tire - http://www3.towerhobbies.com/cgi-bin...?&I=LXFBV7&P=0</div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div> |
Thanks for the info. I have picked this comb over at Towerhobbies.
Wheel-http://www3.towerhobbies.com/cgi-bin...LXM875&P=0 Tires-http://www3.towerhobbies.com/cgi-bin...LXFBV7&P=0 <br type="_moz" /> |
Proline dirtworks are great onroad tires despite the name.
How about this wheel and tire combo?<div>
</div><div> </div><div>Tires - http://cgi.ebay.com/NEW-DuraTrax-Str...d#ht_717wt_905</div><div> </div><div>Wheels - http://www.amazon.com/gp/product/B00...=A2HUFQYBB8LM3</div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div><div> </div> |
Yes, those will work.
They have been ordered!!!! Thanks!!!!!!!!!!!!!!
One more question... do I need to have this combo of wheels and tires balanced?????
No, but you need to glue then. I use a medium thickness CA. If there is chrome plating around the bead of the rim, remove it with some sandpaper, or scrape it off with something, as the CA will not bond to chrome that well.
I have one more question, a little late, but are these size tiresand wheel required to have a foam insert? If so, could someone please recommend one?!?!?!?
Usually foam tires have lots of benefits as compared to air type tires .so I personally believe that foam tires are better.There are various foam tires avaliable such as Matrix foam tires,sedan foam tires and even Gecko are some of the varieties.
ORIGINAL: blusls I have one more question, a little late, but are these size tiresand wheel required to have a foam insert? If so, could someone please recommend one?!?!?!? Stuff these in there http://www3.towerhobbies.com/cgi-bin...?&I=LXAMF7&P=7 |
Thanks for the pointer!!! Ordered and on the way.
