MT4 No throttle
I just installed a new mamba max pro sct on my Losi ten SCTE., also put in a new Airtronics MT4. Now, the problem is that when I press for throttle nothing happens, steering works but no throttle. I spent about two hours with a rep from Airtronics but could not get the thing to work properly. I've read about calibrating the esc but I have no idea on how to do it. Any help will be appreciated.
RE: MT4 No throttle
the esc should have come with calibrating instructions. when you pull the trigger, do you hear any noise or see any lights on the esc light up? also have you made sure that the esc is plugged into the right channel? i know i've plugged it in the wrong channel before, and all i have are 2 channel radios:) and finally, is the esc switched on? again, been there done that.
RE: MT4 No throttle
To calibrate a mamba max pro, turn on the radio and hold down the throttle trigger. Now turn the esc on while still holding the throttle. The ESC will beep and then flash, wait til it's finished beeping and move the trigger forward to full brake. The ESC will beep a few times again. Now leave the throttle in neutral, the ESC will beep again after a couple of seconds, then it will reset and arm. You should be good to go.
RE: MT4 No throttle
Thanks for the response guys. Foxy, I followed your instructions and it worked. I you forward movement but no reverse
RE: MT4 No throttle
Sounds like you might have waited too long between full throttle (starting position) and reverse (trigger full forward). Try the calibration again, this time, be very positive when going from throttle to reverse, do it quickly, don't stop in the middle and hold it until the ESC is waiting for neutral. If you do that and still have no reverse, then maybe it is a settings problem, in which case, you should get a castle link and connect it to a PC so you can see/change the settings.
