Glow plug
Hey guys I just got my savage in the mail and when I tried the glow plug it didn't glow red and I tried the spare one and that dising work either so I got a new c battery and tried it again and it still won't go. Could the igniter be messed up? Because I see no reason why it wouldn't work
RE: Glow plug
I would vote the warmer seeing the chances of 2 new glow plugs being bad should be slim.
RE: Glow plug
ORIGINAL: SyCo_VeNoM I would vote the warmer seeing the chances of 2 new glow plugs being bad should be slim. <br type="_moz" /> |
RE: Glow plug
1 Attachment(s)
If by "warmer" are you referring to the glow-plug ignitor? Assuming so, I agree it is highly unlikely two new glow plugs would be bad. Have you verified you have the battery in the correct way in this ignitor? It should go as the attached picture (this is the exact same ignitor, battery as you have). Forgive me if that seems novice....just a thought of what it could be. Does it glow ANY color at all?
And no - there is no alternative to heating your glow-plug that I am aware of. If you have a hobby shop near you, take the ignitor and plugs in there and have them check it out. While you are there...buy yourself a rechargable ignitor (I've had much better luck with those) Thanks |
RE: Glow plug
ORIGINAL: JohnP2 If by "warmer" are you referring to the glow-plug ignitor? Assuming so, I agree it is highly unlikely two new glow plugs would be bad. Have you verified you have the battery in the correct way in this ignitor? It should go as the attached picture (this is the exact same ignitor, battery as you have). Forgive me if that seems novice....just a thought of what it could be. Does it glow ANY color at all? And no - there is no alternative to heating your glow-plug that I am aware of. If you have a hobby shop near you, take the ignitor and plugs in there and have them check it out. While you are there...buy yourself a rechargable ignitor (I've had much better luck with those) Thanks <br type="_moz" /> |
RE: Glow plug
ORIGINAL: JohnP2 If by ''warmer'' are you referring to the glow-plug ignitor? Assuming so, I agree it is highly unlikely two new glow plugs would be bad. Have you verified you have the battery in the correct way in this ignitor? It should go as the attached picture (this is the exact same ignitor, battery as you have). Forgive me if that seems novice....just a thought of what it could be. Does it glow ANY color at all? And no - there is no alternative to heating your glow-plug that I am aware of. If you have a hobby shop near you, take the ignitor and plugs in there and have them check it out. While you are there...buy yourself a rechargable ignitor (I've had much better luck with those) Thanks |
RE: Glow plug
ORIGINAL: yoyo5 /face palm thank you so much John you saved me 30$ and I was looking at your videos and you I lot of great stuff on there and couldn't find some of that stuff so keep up the good work ORIGINAL: SyCo_VeNoM well the plane guys use warmer, and seeing they poked their heads in so many threads it kinda rubbed off. Well that and warmer don't cause my spell check to spazz like ignnitor does </p> |
