Carson receiver pinout
1 Attachment(s)
I have this Carson receiver and need to know which pins mst be connected for Battery.
As you see there are 6 x 3 pins, but which ones (two) are ground and plus? <br type="_moz" /> |
RE: Carson receiver pinout
Use the "batt."-pins to power it up, but if you are using it together with an ESC this will power it through the servowires.
http://www.carson-modelsport.com/Com...nanleitung.pdf
This is for a 3 chanel carson radio. The pin orientation should be the same. Page 21 Black wire is on the outside. |
Must have expressed myself badly. Let's try again:
There are 6 channel sets of 3 pins, AND there is a set for BATT, which also have 3 pins. I just need to know which 2 of these 3 pins I must connect power to. The connector to this receiver has 2 pins, so it is important to connect it correctly. I suppose that ground is towards the edge of the unit (???) |
Thank you very much Big Alice http://www.rcuniverse.com/forum/js/f...eeth_smile.gif
Lol, i suddenly realized what your nickname means; lead foot:D
That's right.
I referring to my driving http://www.rcuniverse.com/forum/js/f...n/rolleyes.gif |
I thought so:)
