anoying problem with my rc car
please take an look at this video
http://www.youtube.com/watch?v=0NpM_...ature=youtu.be it goes spinning without me touching the steering wheel please help im new here :) |
Hi there, there are many possible reasons for what I just saw, the most likely being that the car is setup for drifting. Do you know if that is or isn't the case? Is this car new to you? Has it ever worked as you expect? IS it 4wd? If so, are all 4 wheels actually being driven? Try to give us as much info as you can. :)
im dutch so sorry for my bad english,
its a drifter its 4wd, all the 4 wheels work fine its my first car i bought it brand new, it worked fine but i crashed and the thing im pointing at with my thump was bend http://i44.tinypic.com/34plu7t.jpg i made is straight again |
I would say that you still have damage in that area, disassemble everything around that wheel and check it, including the shaft on the thick side of the arm, to the right of your thumb in the pic above. As you say, it worked, then it crashed, now it doesn't, the parts need to be right for it to work reliably, especially for drifting.
idk if it was after the crash because i crashed last saturday and today i have this problem and i took it all apart and i wasnt able to find anymore damage
thanks for your help so far :) |
Are you sure the driveline is working ok. What happens when you turn one wheel by hand. Perhaps one of the differentials has a problem?
if i turn it by hand the other wheel follows and how can i see if the diffrential has a problem?
Turn each wheel by hand. If all the wheels turn together in the same direction when you turn each wheel, then your diffs are locked and do not have a problem. If you see any other behaviour let me know.
i think i fixed it, i'm a car mechanic and so im quite familiar with it, i chanced the position of the wheels i made it so that the wheels are like (toe in) https://www.google.nl/search?q=toesp...hp%3B491%3B223 and mine rear wheels where only touching the ground with 10% of the surface now they touch 99% so i have more tration
sorry again for the bad explantion |
No probs, glad you solved it. :)
