how long is your antenna wire?
i got 18 inches on my truck now, i could go to 20, but that sounds ridiculous!!!:) does it matter if its long or not?
RE: how long is your antenna wire?
I think if you go longer you will have a better reception but not alot
hmmm i have this big antenna sticking out and i just wanted to know, tomarrow i will find out for sure, i was just wondering...[&:]
ORIGINAL: ICrashThings i got 18 inches on my truck now, i could go to 20, but that sounds ridiculous!!!:) does it matter if its long or not? longer = further range. |
my anntena is about 10 something inchs long
How come your car glitches if you cut the antenna wire?
my trucks anntena is like 25 inches or so. lol.:D
Just don't cut the antenna wire. It should have been a specific length when stock. You will notice that, with different fequencies and/or channels, the antenna lengths differ. Cutting down the antenna length alters the receiver to another frequency and/or channel. Since you're only cutting the antenna with your naked eye, the frequency can be anything. A manufacturer cuts an antenna wire with acurracy and precision. The antenna wire would receive more clearly and farther with extra length, but not by much. (Also, it will prove very dangerous to drive your R/C car farther than your eyesight!)
ORIGINAL: vizaracer my trucks anntena is like 25 inches or so. lol.:D |
i lost an inch or so of the top of my antenna wire after a flip . do i have to replace it or is it ok?
i tripped while holding my remote and the tip broke off but i lost it and now the reception is realy short how can i fix it?
ORIGINAL: nownnew Just don't cut the antenna wire. It should have been a specific length when stock. You will notice that, with different fequencies and/or channels, the antenna lengths differ. Cutting down the antenna length alters the receiver to another frequency and/or channel. Since you're only cutting the antenna with your naked eye, the frequency can be anything. A manufacturer cuts an antenna wire with acurracy and precision. The antenna wire would receive more clearly and farther with extra length, but not by much. (Also, it will prove very dangerous to drive your R/C car farther than your eyesight!) lately ive noticed that alot of people are using those plastic things that you wrap the wire through the holes like a coil. it makes it so you dont have to cut a hole for the antenna in the body, and it doesnt stick up. i think now radios are starting to get better, and there isnt as much of a need for a long antenna. i was thinking about using a short antenna if i paint a new body for my nt so there isnt a hole through it. |
ORIGINAL: iliketobreakthings i tripped while holding my remote and the tip broke off but i lost it and now the reception is realy short how can i fix it? |
ORIGINAL: ericheller actually antenna lenths have nothing to do with the frequency i dont think. if it did then how come i can change the channel on my radio and it still works just fine. i dont know exactly why cutting the antenna messes it up but it has for me befor(not with my xs3). moral of the story: NEVER CUT OR COIL YOUR ANTENNA |
no wonder, now when ever i turn on my quick drive the steering servo glitches and makes a wierd noise and it moves like a millimetre or 2 each side.
wait...i thought those little tiny frequency crystals changed the damn frequency.......
my antenna wire is so friggin long. i have a good 6 inches hanging out the top of my tube. *** do i do with all of that? it looks like crap
get a bigger tube...if u cant, then (dare i say it) CUT TEH WIRE!!!![sm=lol.gif]
a bigger tube would look totally retarded. Ill get right on cutting that wire too :eek:
ORIGINAL: visible a bigger tube would look totally retarded. Ill get right on cutting that wire too :eek: |
thats what i did. just pulled the excess down, tied and hide ;)
My antenna wire broke so I just twisted the wires back together.
i dom\nt think cutting the wire will do anything. my attena wire got riped out(my friends dog did it) and all i did was strip each end soddered them together and shrink wraped it and now it works as good as new, and it DOESN'T glitch
i had about 7 inches coming out of my antenna tube. i just stuffed it all in the radio box.
if my antenna wire was to rip out of the whole rx box how would i go on fixin that...would i be able to order a replacement wire instead of buying a whole new rx..i have a mx-3 and im worried that my antenna wire will rip and there rx cost like 80 dollars and the whole set wit two servos cost around 120. so yea where could
