RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Car General Discussions (http://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   HOw to tell if receiver is bad? (http://www.rcuniverse.com/forum/rc-car-general-discussions-179/9172614-how-tell-if-receiver-bad.html)
katzcratch 10-14-2009 11:18 AM
I dont know how to tell on my pos hsp flying fish if the receiver or the servo is not working. The car responds to the throttle, but no response to turining?
the thing is almost new. Ihave tried hooking unhooking leads, holding throttle when Iturn car on to reset. There is not a reset switch on the esc...Any ideas please?
Druss 10-14-2009 11:23 AM
RE: HOw to tell if receiver is bad?
Since you know for sure the throttle channe on the receiver works just plug the steering servo into the throttle channel and see what happens. If the servo still doesn't work then it's a bad servo, if the servo works then it's a bad receiver.
katzcratch 10-14-2009 11:52 AM
ok.. SO right now there are 3 ports on the receiver channel 1 chann 2 and battery
the servo connects into the battery port...so would Iplug the servo into the channel port that Iam using for throttle?
and this may sound stupid, but will I just pull the throttle? or turn the wheel
thankyou!!
</p>
Druss 10-14-2009 12:08 PM
Your servo should not be plugged into the battery port...
It should be plugged into one of the channel ports, the one that the throttle (esc) is not plugged into.
The battery port is for a separate battery when you're running nitro which you don't need because the car is an electric.
katzcratch 10-14-2009 01:19 PM
Hmm
I will find out if that is the problem...I hope it is something that simple/stupid
thankyou..will try  to night
s1dn13y 05-24-2010 02:40 AM
Sup guys, My switch On and OFF from the chassy wont work. I wonder if its the switch or the reciever?
coz when i switch it to On nothing, not even the servo no respond, I replace a new batter from the chassy and also from the Controller.but the controller works it lights up except for the chassy no respond. any clues? thanks!
hpidriver94 05-24-2010 02:41 PM
because the ESC has a BEC which gives the reciever its power so you will need to use a reciever battery to test it.
