RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
Traxxas TQi thoughts??
Reply
Old 03-30-2012, 06:51 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Traxxas TQi thoughts??
Hey guys whats ur thoughts on the TQi????
I personally love its telemetry and ipod dock.
Ive heard it feels cheap , but there is no real facts to that. maby those people could fil it up fith some weights & make a lether grip with diamond studs... lol
Im currently running the Traxxas Link 2.4ghz 5ch on 5 out of 13 cars & plan to upgrade the rest to run of the one controller.
Im mainly running that TX because i dont know of any other that controll 5ch.
Ive since found out that the TQi is compatable with the RX's i use. how cool is that
So im planing to upgrade my TX tothe TQi and outfit my other cars with the telemetry RX's
What u guys think, know a better 5ch pistol grip TX with model memory?
phmaximus is offline
Old 03-31-2012, 05:35 PM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Traxxas TQi thoughts??
Here is some info on them
MODEL 6507: TQi Transmitter, 4-channel with 5-channel Receiver and Docking Base
MODEL 6508: TQi Transmitter, 4-channel with 5-channel Receiver
MODEL 6509: TQi Transmitter, 2-channel with 5-channel Receiver
MODEL 6510: TQi Docking Base
MODEL 6518: TQi 5-channel Receiver
*Sleek Design with Internal Antenna
*5-Channel Receiver with 3 Telemetry Ports
*Traxxas Link Model Memory for up to 30 Models
*Simple 2-Button Programming Interface
*Built in Failsafe
*Direct Sequence Spread Spectrum Technology (DSSS)
*Uses only 4 AA Batteries
*Accessory Docking Base Connects TQi with Apple iPhone or iPod touch
*Traxxas Link Application Provides Visual Access to: *Real-Time Telemetry
*Customizable Dashboards
*Steering/throttle expo
*Steering/braking dual rate
*Servo reversing
*Endpoint adjustment
*Profile customization and sharing
*Manage an unlimited number of models with the Traxxas Link App
TQi 2.4GHz Radio System Features:
*High Output signal for maximum range
*Integrated internal antenna
*Simple 2-Button Interface
*Steering trim and Multi-Function knobs
*Adjustable steering and throttle percentage (dual rates)
*Adjustable steering and throttle sensitivity (exponential)
*Adjustable steering and throttle end points
*Automatically stores and loads settings for up to 30 Traxxas Link Model Memory enabled models—just switch on and drive, "model selection" is not required.
*High 13ms frame rate and near-zero latency for responsive control
*Telemetry enabled 5-channel micro receiver with dual channel-1 inputs
*Comfortable ergonomic design
*New steering wheel and foam grip
*Operates on just 4 AA batteries
TQi Docking Base (#6510) Features:
*Quickly installs on the TQi transmitter
*Accepts Apple iPhone and iPod touch
*Height adjustment pads included for iPhone and iPod touch devices with and without cases
*Secure clamping mechanism holds iPhone or iPod touch in place via three rubber padded cleats
*Capable of charging Phone or iPod touch
*Accepts accessory 5-cell NiMH rechargable battery pack (#3037)
*Integrated charge jack for use with NiMH batteries
*TQi Docking Base included on select Traxxas vehicles
Traxxas Link Application Features:
*Intuitive iPhone and iPod touch interface
*Customizable Dashboard *Dial or digital readout gauges
*Up to nine gauges can be displayed at one time
*Set threshold warnings and log maximums, minimums, or averages
*Review telemetry feedback via the dashboard recording function that includes sound
*Instant replay feature captures the previous 60-seconds of dashboard activity
*Recordings can be named and saved
*See telemetry feedback from electric and nitro models for speed, temperature, and voltage
*Edit, save, and share drive profiles
*Visually manage an unlimited number of models with the Traxxas Link App and see: *Transmitter model history
*Model names
*Customizable settings
*Profiles
Old 03-31-2012, 05:46 PM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
#6523 - Temp/Voltage Telemetry Sensor (short)
#6521 - Temp/Voltage Telemetry Sensor (long)
#6535 - Temp Sensor Mount for Electric Motors
#6522 - RPM Telemetry Sensor (short)
#6520 - RPM Telemetry Sensor (long)
#6541 - Power Tap for Voltage
Sensor with Cable and Accessories
#6860R - Motor Mount for Models 6808,6807, 6708
Blue-Anodized Machined Aluminum
#6860A - Motor Mount for Models 6808,6807, 6708
#6538 - Spur Gear Telemetry Trigger Magnet Holder
#6539 - Center Diff Telemetry Trigger Magnet Holder
#6540 - Telemetry Trigger Magnet (5mm x 2mm)
#5677A - Sensor-Ready Gear Cover for Model 5603
#5677R - Sensor-Ready Gear Cover for Models 5608, 5607
#3977A - Sensor-Ready Gear Cover for Model 3903
#3977R - Sensor-Ready Gear Cover for Model 3908
#3792 - Sensor-Ready Gear Cover for All Rustler, Bandit, Stampede
and 2wd Slash
#6537 Wire Retainer
#7077R - Sensor-Ready Gear Cover for 1/16 VXL Models
#7379R - Sensor-Ready Gear Cover for 1/16 Models
with Titan 12T
#7045R - 45-tooth Spur Gear for Telemetry
#7046R - 50-tooth Spur Gear for Telemetry
#7047R - 55-tooth Spur Gear for Telemetry
#6542X - Flywheel for Telemetry
(large, knurled for use with starter boxes)
#6542 - Flywheel for Telemetry (35mm)
#6536 - RPM Sensor Mounts
for Nitro Models
#6550 - Telemetry Expander Module
Plugs directly into the TQi receiver and
allows the use of additional sensors and
the GPS module
#6551 - GPS Module
Provides the most precise speed
information based on GPS location instead of RPM
Old 04-01-2012, 04:04 PM
TheKennyKiller
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They look pretty good and if you're in to the iPhone thing I guess it will come in handy. A buddy of mine over on the Summit thread says the wheel is smaller then the old one and it feels a little tight, it might loosen up with a bit of use though.
TheKennyKiller is offline
Old 04-01-2012, 04:33 PM
Summit is Beast!!!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My buddy just bought the "slow POS toy" summit according to phmax. The new 1...i have the 1 b4 the new 1. I hate hate hate the new controller, its tiny compared to mine and the wheel is super tight and id say a half inch smaller than my wheel. Which means alot to me maybe not to others. Thats just my opinion tho, but hey what do i know im an unexperienced noob right.
Summit is Beast!!! is offline
Old 04-02-2012, 02:00 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hummmm little tight.... that might be a easy fix... might look into that
I see what u mean by the size....
Old 04-02-2012, 02:17 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That sucks about the wheels size, Dammmm. still if there is a will thereis a way....
Before u upgraded to 2.4ghz i use to use the HPI/Onfa radios. and was use to the nice rubber grip.
When i went to the traxxas controller I hated the feel of the foam & it felt to small. Allso I dident like the fact that it dident show the voltage like most other 2.4ghz controllers, but it was the only controler that could controll 5ch. even tho its listed as a 4ch.
Well anyway this is what I did to my controller. I fitted a volt meter & a touring car tyre to the wheel.... dare say might be able to mod the newer controller in the same way.... Untill the new controller came out I was planing to Jam a BEC in it & run a lipo... the advantage would be i could run it if any voltage battery providing it fitted.
Here is one of my current controllers.... soon will be up for sale with reciver & i will be selling a non "link" one with a reciver
Old 04-02-2012, 02:21 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is the older style controller I was use to... I sold if off with the car pictured.
Old 04-02-2012, 04:50 AM
Summit is Beast!!!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmmmmm thats a pretty sweet controller. How much will u be asking for it?
Old 04-02-2012, 06:36 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dont know yet... around $60-70 with spare arial & the 5ch reciver only because the recivers are around $30 so thats only $30-$40 for the controller itself with a spare arial For a additional $10 i can sepperate the 4th & 5th channel so they have there own switch....
Old 04-03-2012, 02:20 AM
TheKennyKiller
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Summit is Beast!!!
If you buy it at least you won't have to worry about supplying your shipping address. [X(]
Old 04-03-2012, 02:49 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LMAO now now, lol
Old 04-03-2012, 11:51 AM
Summit is Beast!!!
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lmfao i was thinking the same thing!
Old 05-15-2012, 05:14 AM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I've had my controller for a few weeks now, and love it...
Problems well I left it in the car and one f the kids stepped on it braking off the lever for the dock, still works ok just harder to lock a iPod in.
Only other complaints... It can't be changed from mph and f to km/h and c.
Oh and u can't set custom wheel sizes....
Old 06-10-2012, 11:01 PM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
woot not long till the expander comes out
Old 07-19-2012, 11:54 PM
phmaximus
phmaximus's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[link=http://investors.cypress.com/releasedetail.cfm?ReleaseID=690879]Traxxas Selects Cypress's WirelessUSB-LP™ Radio Solution For World's Fastest Ready-To-Run Radio Controlled Car[/link]
Old 08-07-2012, 03:01 AM
bigblock454XXL
bigblock454XXL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always wanted one since they came out and I now own the XO-1. It's a nice controller and the size of the wheel was my first thought. But to me a smaller steering wheel is a great idea. It was so good that I bought my 6 year old son the TQi controller too for his 30th Anniversary Grave Digger. I love the no-folding antennea. My son has had his truck 3 weeks and has allready broke the antennea and bent the second one. Not from abuse but from trying to push it in. Hahaha. I've broke a few too in my lifetime. So finally words. I love the TQi and haven't found anything wrong with it. But I race my Short Course truck with a Spektrum.
bigblock454XXL is offline
Old 10-10-2012, 07:51 AM
dadon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some of you said they look cheep..... hmmmmm I have one here this new style with docking base for ipod. It developed a problem and LED doesnt go on as well as the top part of the TX is dead. When Ipod is connected and I switch on button the Ipod is binded with TX but the TX does not work and no LED light.
I spoke to 2 people with exactly same problem. I think TQI with docking base is not yet fit for general sale. Obviously there are some problems which are not yet sorted out.
BTW - if anyone knows hot to fix top of the TX (as docking base is working) please let me know.
dadon is offline
Reply
Display Modes
