Help with flysky radio
Hi, I just bought a new radio and reciever for my emaxx it is the flysky gt3b 2.4 sold by hobbypartz.com. My problem is that i cant bind the reciever to the radio. The reciever is blinking slow not fast and after 2 seconds of turning the esc on it barley blinks green real fast then just goes. Ive tried adjusting all the settings i am also having this same problem for the reciever for a boat that im trying to use this setup for also. Im not sure what to do I cant get a hold of the manufacturer.
RE: Help with flysky radio
did you use the little loop back plug on the batt connector?
Do this put the loop in the batt connector and turn the RC on making sure the RX has power. Then while holding the button to link it up turn the radio on. Let go of the button.
Turn the ESC off, remove the loop back thing off the RX, and turn the radio off.
Then when you turn it all back on it should be set right if I remember it right.
