RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
Running LEDs off radio channel?
Reply
Old 03-10-2014, 05:46 AM
Northern Mike
Northern Mike's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Running LEDs off radio channel?
I've seen these 3w LEDs for sale that are setup to run off a spare channel on the radio. All its doing is doing is grabbing power.
Is this a bad idea powering LEDs off the radio? Personally I think it is, but I may be incorrect.
Thoughts?
Northern Mike is offline
Old 04-30-2014, 12:36 PM
EXT2Rob
EXT2Rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would say generally not a good idea, unless you're running an external BEC. You don't want to compromise your Rx power, or risk overloading the on-board BEC. Now, that said, if you're only talking about one or two LEDs, you might could get away with it. Depends on the ratings of the particular LED. Some LEDs require more voltage to emit enough light. Red LEDs require less voltage than blue LEDs, and therefore will be brighter than the blue ones on the same circuit. So you then have to get into balancing the circuit if you're using multiple LEDs and more than one color. Balancing the circuit requires some knowlege of electronics, or a good Google search might turn up an "LED balancer" app that can help. But in the end, you're better off using an external BEC or a 9V battery.
EXT2Rob is offline
Reply
Display Modes
