RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
Futaba 3PL - no steering
Reply
Old 12-03-2018, 12:27 PM
triver525
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba 3PL - no steering
I just bought a used Futaba 3PL that came with two R2004GF receivers. I plugged everything in and I was able to bind the receiver to the transmitter no problem and the throttle controls the ESC perfectly. The problem comes in when I plug the servo into CH2. The servo runs all the way to one end and sits there and buzzes.
I tried pulling down the end points on the transmitter, turning the wheel fully, etc etc. It even does it with the transmitter off.
Servo is a Trackstar TS-P12S. It is just a small digital servo which worked perfectly with the Spektrum radio that was stock.
Any ideas?
triver525 is offline
Old 12-03-2018, 01:14 PM
Big Alice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[QUOTE The problem comes in when I plug the servo into CH2.[/QUOTE]
Steering goes on channel 1... Manual https://www.manualslib.com/manual/378255/Futaba-3pl-2-4g.html
Big Alice is offline
Old 12-03-2018, 05:10 PM
triver525
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I checked the position I plugged it into and it was channel 1. When I turn the wheel full left I can get the servo to center and stop buzzing. Anything off of full left drives the servo to the end.
Old 12-03-2018, 05:12 PM
triver525
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, when I turn the transmitter off it stops.
Old 12-03-2018, 11:51 PM
Big Alice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Have you tried a different servo to see how it act in there? That'd probably be the next step. Does it act the same way using the other receiver?
Old 12-04-2018, 04:20 AM
RustyUs
RustyUs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 ^^^ on checking other receiver.
Since channel two (throttle) works fine, I would also swap channel inputs on the receiver to use the transmitter's trigger to send signals to the servo.
RustyUs is offline
Old 12-04-2018, 04:58 AM
RustyUs
RustyUs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's quite normal for digital servos to "buzz" , or make noise even when steering is in neutral position.
RustyUs is offline
Old 12-04-2018, 12:52 PM
Big Alice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another thing to check is the wiring orientation in the plug. They're pretty standardized now days but it could be different. I've had that problem with KO Propo servos in the past. I'm not up on all the digital stuff but it's something else to check.
Old 12-05-2018, 09:55 AM
RustyUs
RustyUs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any ideas?
I'm not quite sure what you mean by pulling down, but the steering EPAs (both Left and Right) are set to 100%? My thinking is the right EPA is somehow set to 0%. I
'am out of ideas.
Good luck!
RustyUs is offline
Old 12-06-2018, 08:49 AM
RustyUs
RustyUs's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Futaba Radios Direct support forum
RustyUs is offline
