JR XS3 users help me
OR
Hey Guys,
I'm running the 5645mg servo for steering, the EPA is way to much, but when I reduce the EPA is seems to reduce the speed and torque of the servo. not just alittle but ALOT!
Am I doing something wrong? what gives...
Thanks for your help
RE: JR XS3 users help me
RCBros
What length servo arm are you using?
You need to set the EPA at 100% each direction and move the steering link in towards the centre of the arm until full steering wheel turn in both directions gives full front wheel turn WITHOUT binding.
This gives you the max torque and resolution from your servo. If the arm is too long and the EPA is reduced you are not using the full capability of the servo.
Jeff
Jeff
