Need Help!
Need Help!
Never used 4 channels!
I want to get a 4 channel or 6 channel radio for special circumstances for ground use only. Can i change the reciever to from 72mhz to 75mhz easily? Should i just stick with 72mhz; remote spot. I only really need 4 channels and possibly a 5th so does it hurt to get a 6 channels for the hell of it and be safe even though two channels are not being used?
This is my original post:
If I was to run two electric motors on one receiver with a forward and reverse esc, and a seperate electric engine on another reciever with forward and reverse esc, all in the same vehicle... What radio would i need? I was told a 4 channel. Need some help on this one and it's a special application. For that apllication with the 3 motors do i need 2 recievers?
React looks cool but pricey!
Thanks for the help
Thanks for the help
RE: Need Help!
Trust me it's a solid project but if tell everyone what it is, it will stray from the original topic or answer i'm looking for.
RE: Need Help!
The reason behind asking the project is because in some of the radios the additional channels are only a on/off function.
I have a 5 channel for my heli, and the 5th channel is like that.
RE: Need Help!
It's an rc fishing boat! Two engines to power the boat, one to reel out the line and bring the line back in. and possible use of a servo.
RE: Need Help!
4 channel would work for that.
Channel 1 & 3 could be throttle (one motor on each channel) (so left stick fwd/bkw motor one, right stick fwd/bkw motor 2)
Channel 2 steering (left (or right) side to side steering)
Channel 4 for the aux motor (same thing)
If you did want to do a 5 channel, you could get a simple on/off for something like running lights.
I run a Spektrum radio on my 5 channel.
