swissflash/tamiya tyrell
i bougth this at a garage sale, where can i get a motor that fits? i think i need a plane motor.
i can upload more pics if you want to.
RE: swissflash/tamiya tyrell
well noone seems to know what it is, but they did find one just like it:
http://tamiyaclub.com/showroom_model...4923&sid=19103
it's a start.
it's a start.
thanks for the link kaiser! it seems like i have oto machine myself some tank mounts, and make a new radioplate for it. i have removed most of the rust, and washed the rest of the parts.ut i can't seem to find a motor that will fit properly.
Aha, no veit eg kven du er, hehe
I guess it is not hard to fabricate some new engine mounts here, but you might have to move them closer or wider to accept a new engine in the car. And you also might have to lower or raise them to get it lined up with the clutchbell. Brushless conversion can also be done, but then it will loose some of its original charm with being a nitro.
jepp, må bytte avatar slik at det er likt her også :P
the engine mounts fits a .21 engine, but the crankshaft is too long, and the exhaust hit the side chassie plates, so i will need a side exhaust engine.
Since Tamiya Tyrell P34 was never available in nitro configuration, I doubt its part would apply to this vehicle at all.. looks like you need a small nitro engine... or you can probably convert it to electric with some custom made motor mount..
ORIGINAL: Lunchboxer
Ive even tried Swissflash......but i keep getting knives with flasdrives...lol
What scale car is it?
if anyone got a engine that will fit and are willing to sell it to me and ship it internationaly, i will be wery happy.
i am in the midle of making thicker chassie, and making a servo/tank brace.
i have done alittle of work to it, the engine is a old .21 without crankshaft. i made a plate for the tank and servos, aswell as a 4mm milled chassis, and i have started to polish the wheels, and remove corrosion on alu parts, aswell as rust on steel parts.the suspension arms where so rusty that i had to make new ones. so far, i am happy with it:
looks awfully nice, so you have an issue with the crank being too long in most standard .21's? why not get a machinist to cut it and re drill and tap it?
i am a machinist i could cut the crank, but i would rather have the orginal motor, a veco .19. i am now in the process of polishing all parts.
