RC Classic Cars & Trucks Have a classic that is at least 15 years or older? Discuss it here!
RC10T
Reply
Old 10-17-2011, 06:48 AM
gibsontoad
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RC10T
I have an old rc10t that i need to replace the rear three peice rims...does anyone know if i can replace them with the new rims or where i can go to buy the old ones, thanks
gibsontoad is offline
Old 10-17-2011, 08:23 AM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC10T
You need to convert over to the 3/16th axle, which requires different axle carriers.
You need [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGEJ8&P=7]these[/link], [link=http://www.amainhobbies.com/product_info.php/cPath/1_25_1450_42/products_id/1705/n/Team-Associated-Rear-Hub-Carriers-GT-15]these[/link], [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPA18&P=ML]these[/link], and lastly [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2563&P=7]these. [/link]
Hope this helps. I did the conversion a while back and didn't need a shim kit.
proanti1 is offline
Old 10-17-2011, 02:56 PM
Big Alice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC10T
You won't have to change thehub carrier. The od on the bearings is the same size. Or you could just buy a wheel to fit your 1/4 axlel. If it was me doing it, I'd switch to the 3/16 axle. Lot better selection of wheels to choose from. The 1/4 stuff is way obselete.
http://www3.towerhobbies.com/cgi-bin...?&I=LXMSY1&P=7
Big Alice is offline
Old 10-17-2011, 02:59 PM
Big Alice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC10T
nm I found the edit button
Old 10-17-2011, 05:04 PM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC10T
ORIGINAL: Big Alice
You won't have to change the hub carrier. The od on the bearings is the same size. Or you could just buy a wheel to fit your 1/4 axlel. If it was me doing it, I'd switch to the 3/16 axle. Lot better selection of wheels to choose from. The 1/4 stuff is way obselete.
No, the old rc10t axle is a bit different, and longer on the inside. If you were to use the stock axle carrier, the 3/16 axle would not reach the dogbone. The stock axle carrier is also wider, and doesn't allow you to even insert the split pin. The rc10gt carrier is a requirement when using the 3/16 axle. I went through all this when I converted one of mine over.
proanti1 is offline
Old 10-18-2011, 02:22 PM
Big Alice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC10T
Didn't know that. Someone must have switched them on my trucks before I got them. mine just went right in when I switched over. Both my T's were bought used.
Old 11-02-2011, 01:17 PM
zman5000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RC10T
it was probably a deal like mine which was raced and modded. these rc10t's were built to race and on mine i have Ti cvd's and turnbuckles and so on. i gotmy 10toff the shelf and it still works.
zman5000 is offline
Contact Us Archive Advertising Cookie Policy
