Return of Lunchbox..
#4727
RE: Return of Lunchbox..
Cool mods! [sm=thumbs_up.gif]
So you need some kind of bracket to mount the CRP arms?!
ORIGINAL: alaskadf300
Wow!, Hope you get it squared away soon. Here are two pics of my slow build progress. The first shows the hand-made bracket mounting for the CRP upper arm pivot. The second is another hand-bent aluminum servo mount, this is after I saw many photos of cracked and warped plastic where the sevos mount.
#4728
AK
Thank you, yeah, the bracket makes the arms much more parallel than they would have been. I will post pics within moments, kinda went on a building spree.
#4732
AK
See previous page for close-up of CRP bracket mount, and yes, the shocks are longer than expected. They are Kyosho W5143, and I got them at a great price. So what if it's more top heavy, I'll be able to jump 14 garbage cans!, Ha!!.
#4735
You can always put some spacers inside the shocks to shorten the travel, if you feel its too tippy.
Now go and build an independent rear suspension!
#4736
AK
Ha!, I actually like the rear setup since it's so bulletproof. I only put it the CRP kit to keep the front tires at non-silly angles when cruising over bumps. If I can get away with it, I may someday put another LB gearbox in the front with twin brushless motors and custom length shafts.
#4737
That would be crazy! But I think it has been done before...
#4738
AZ
ORIGINAL: Lunchboxer
Something does not smell right.. ha! I think it is next to impossible to strip any LB gears...
sorry for blurry pictures
#4739
AK
That may be blurry, but it clearly has missing teeth. I think your camera locked onto the dead action figure in the background, LOL.
#4741
AK
Ha!, I have a 1/12th scale Dr. Evil action-figure that may end up in my LB, just have to fab an interior. Hope you can fix the gear problem and end up with a truly tough gearbox that doesn't fail again.
#4743
AK
Yep, but it would cost the same as buying 5-6 lunchboxes. The thought did cross my mind, but rather than having them made, I was going to hunt for the nearest fit, gear by gear until I had set that would function.
#4744
Oh, I am sure everything is possible.. but just saying it is odd when people can run 300 watts system through it and it holds up fine.. while you broke 2 spurs in 10 runs?!
ORIGINAL: Stampede Killer
oh its possible, see.
#4747
AZ
well, im thinking about using the 18t pinon from the hornet, to get not so much torque, and when i get brushless, i will try the mm 4700
#4749
A good way to do the 3rd shock? It should be really secured, but the rear axle flexes.. so I am not so sure about having the shock mounted this way (through the steel pin) is the way to go?! Hmm...
