Return of Lunchbox..
#5152
RE: Return of Lunchbox..
sometimes when i run a brushless system in my lunchbox it stutters a bit.. as if the batery is dead flat.
is this because the motor is sencing it is slightly jammed because of the low gear ratio?
would sensorless cure this?
#5154
Sensorless will be less smooth if anything else, though.... I have never had problem w/ sensored system.. for sensorless, you need good batteries..
ORIGINAL: lbshelfqueen
#5155
Are you running an AM Radio on your Box? This caused serious stutter on my brushless box (Novak like yours) when reaching a certain distance.
ORIGINAL: lbshelfqueen.
#5156
ON, CANADA
ORIGINAL: Lunchboxer
I am sure they are 1/2 price here in US... so maybe look at eBay or have me order it from Tower or something...
http://www3.towerhobbies.com/cgi-bin...?&I=LXGG67&P=Z
Less than 12GBP per set..
(howcome there's 4 springs when the kit makes 2 shocks?)
#5157
yes its am.
but it will stutter when the car is a few inches or 50 yards away. also sometimes the steering feels a bit delayed when i used it brushless. could it interfear with the reciever? would that make it stutter. might try and move the reciever towards the front and have the antena coming up near the windscreen
#5158
AZ
ORIGINAL: frugalman
those look shorter than the stock ones..
#5159
They are slightly shorter... lower the front a little bit.. ha! Gives it some negative camber!
4 springs -> 2 soft, 2 hard....
ORIGINAL: frugalman
#5160
There's your problem. Brushless systems seem to cause some interference with AM receivers. Try to run the antenna as far away from the motor/ESC as possible. I used to run the antenna inside the chassis, now it's simply straight up the antenna pipe and hanging down from the top. No problems since. But I'm changing to 2.4 GHZ anyways.
yes its am.
yes its am.
#5163
ON, CANADA
love the decals
it's pre-cut! just great
*edit
pics are coming from first real run
the lower screw fell off on the front shock joint
hmmmm
*edit
hmmmm
#5170
ON, CANADA
ORIGINAL: Stampede Killer
nice, looks great, did you build it? i which i could get my lb running. i need a new pc though[:@] stupid bsod
i don't prefer XB series all too much
PC ?
#5171
AZ
ORIGINAL: frugalman
yes it's the kit so i did build it
PC ?
PC ?
#5173
ON, CANADA
good job on the paint, and yes its a pc, going to build a new one, this one i got when xp first came out
got pics of yours?
i have an extra hard shell.. wondering what color i should paint it
was thinking gunmetal or dark grey ..
