RC Classic Cars & Trucks Have a classic that is at least 15 years or older? Discuss it here!
Return of Lunchbox..
Old 03-16-2012, 04:18 AM
  #7626
StevenJV
Default RE: Return of Lunchbox..
Thanks Hwa224, I added the Tamiya connector to my order, only $3 for just in case and have everything on its way to me.  And thanks for explaining some of that diff in chargers.
I remember the charger I used to have was like carrying a toaster around.  These are pretty fancy and the costs...they sure have changed.  Way less then what I paid back in the day.
Old 03-19-2012, 02:47 AM
  #7627
Bootnut
ORIGINAL: Timmy2Tracks
ORIGINAL: lbshelfqueen
i really really need those alloy uprights.. any idea where i can get some?
Here ya go, my man. They make nice stuff, and ship qucikly.
http://www.junfac.com/shop/index.php...0b73b415f1513b
If i get these, what axels do i use? cause the ones on the lunch box are attached to the plastic thing upright? do Junfac sell axels to push into these new uprights? or another model i can get them off?
Old 03-20-2012, 09:34 PM
  #7628
Hwa224
Hwa224's Avatar
StevenJV,
Very important information about your FlySky You may have to bind your receiver to your transmitter.
You'll find instructions on how to do this at various websites, but here's information you'll need if your receiver is like the version that I recently received:
(1)With your receiver powered up (a power source through the "vcc" slot) and with the bind plug in the "Bind"/channel 3 slot, your receiver is supposed to blink.
(2) When you hold the transmitter bind button and then turn on your controller, that blinking light turns solid after about 3 seconds.
However, it appears FlySky are getting cheap with their circuits. So instead of the above, what you'll see with the bind plug in the bind slot is a solid light. Hold the bind button on your transmitter, then wait for about 3 seconds or more. The rx and tx are now bound - even though you didn't start with a blinking led etc.. Remove the bind plug and test. The two should be bound.
Old 03-23-2012, 09:55 AM
  #7629
StevenJV
Ok thanks for that.
I was out of town for a few days but all my shipments arrived and are waiting for me to crack boxes.
I've also been waiting for power supplies to get off of "backorder" status at hobbypartz.  I keep watching the G350 to be available while searching for a comparable product in price and specs.
Old 03-26-2012, 12:00 AM
  #7630
lunchie
NEARLY DONE!
just about ready! all i have to do is make up the body mounts and setup the steering geometry and a few cosmetic things like custom licence plate.
third shock all mounted.
Front shock and rear tray braces all fitted up and the wheelie bar brace...made from 3mm stainless threaded rod.
you can also see my custom gear plate for the radio gear. i just cut down the two "towers" that were used to hold up the mech speed control and bolted the plate to the bottom of the chassis. I may swap it out for a plastic one if i get glitches.
enjoy the pics.
Old 03-26-2012, 12:05 AM
  #7631
lunchie
heres the pics
ID:	1742972   Click image for larger version
ID:	1742973   Click image for larger version
ID:	1742974   Click image for larger version
ID:	1742975   Click image for larger version
Old 03-26-2012, 04:01 PM
  #7632
Hwa224
Hwa224's Avatar
Still nothing like an immaculate Lunch Box, freshly built. I love the blue dampers. What brand are those?
Old 03-26-2012, 04:14 PM
  #7633
Scratch2k
ORIGINAL: lunchie
heres the pics
I love the strut brace, much classier than my trimmed spare back panel insert from an old PC.
Old 03-26-2012, 10:36 PM
  #7634
lunchie
They are 78mm integy. Fronts are shortened 85mm hsp
Old 03-27-2012, 12:02 AM
  #7635
Bootnut
Nice bracing! I have the same on my lunchbox and pumpkin wheelie bars, I noticed you have a couple more in other places, something for me to try on a rainy day.
This weekend we had some monster truck races
Midnight pumpkin - Tamiya BZ dirt motor - aftermarket aluminium wheels, stock tires
Lunchbox - Tamiya Sport tuned motor - standard plastic wheels
Both trucks have the same brand oil shocks, 3rd shock mod etc, anyway the lunchbox won the races every time. It’s my favourite truck again hehe.
I also raced the pumpkin against my brothers stock 1/10 Traxxas Grave digger, it was a really even match maybe swaying to the grave digger. So I’m taking the lunchbox next time, maybe some softer springs, I will beat him!
Old 03-31-2012, 08:47 PM
  #7636
lunchie
HELP!
well after the first two batteries i have had the pinion grub screw loosen off and now the servo screw fall out GRRRRRRR!
time for some loctite?
also how long do you get on a stock lunchbox with a 3000mah battery?
my lunchbox feels ssssssssoooooooooo ssssssslllllooooooowwwwwww. i mean really slow.
it lacks punch off the line, and feels like a cheap nicco store car barely able to get through the grass.
do the nimh batteries get better with age/use?? (duratrax onyx 3000mah.)
Old 04-01-2012, 07:28 AM
  #7637
Timmy2Tracks
ORIGINAL: Bootnut
Bootnut: You can slide them (axles) out of the plastic Tamiya uprights, and slide them into the Junfac units. If you tap the metal axles with a punch or a nail, they will pop right out.
Old 04-01-2012, 01:24 PM
  #7638
Hwa224
Hwa224's Avatar
With 3000mah battery, you should get 30 minutes or more on stock motor. On a 3800mah battery I got more than 40 minutes. And the LB had a good punch to it. Not of course much of any top speed but it was zippy even with the silver can.
Make sure your battery is a genuine 3000mah battery or is not defective.
On grass, however, the silver can is barely able to push the LB.
ORIGINAL: lunchie
HELP!
Old 04-08-2012, 01:16 AM
  #7639
lunchie
haha so now my 5 year old has broken the body moounts and dislodged the front chrome bumper. need to make up some new body mounts
Old 04-09-2012, 04:51 AM
  #7640
StevenJV
Got my power supply and charger setup.
Exciting to me only but posting an update.
Also did some body painting this weekend and came to work with green paint all over my hands. I think I got the paint on the wrong body.
Old 04-10-2012, 07:09 AM
  #7641
StevenJV
got the paint done with and gave the LB a trial run outdoors
Just need to tighten up the electics inside
paint and glue the wheels
then get ready to fix everything that breaks as soon as my kids have at it.
I think I'm going to pick up a parma body and spend time detailing that and get more experience with painting
Old 04-18-2012, 11:21 PM
  #7642
lunchie
come on lunchboxers!!!
where are you all??
dont let the yellow van die!
Old 04-19-2012, 07:29 AM
  #7643
magic2002
magic2002's Avatar
don't worry it is very much alive... so much even we don't have time to post here..
meanwhile, enjoy... http://www.youtube.com/watch?v=xPVtBlcvb2U
Old 04-19-2012, 08:23 AM
  #7644
Lunchboxer
Lunchboxer's Avatar
Nice video!!
Old 04-19-2012, 08:00 PM
  #7645
Hwa224
Hwa224's Avatar
StevenJV,
What a sexy beast your LB is! I like the green..? Looks nice. It looks blue in one of the slides of your pic, unless that's a different body.
In RC, there's a tension, a constant battle between liking the hobby because you have a beautiful RC car vs liking the hobby because running that RC car is fun. The problem is that these two things are almost mutually exclusive. The more you run the car, the more crap it looks, the more it gets damaged, which = ugly RC. LOL.
But a moist microfiber towel can do wonders. And good driving skills.
Old 04-20-2012, 04:16 AM
  #7646
StevenJV
Its a metallic jade green I think. it was a can of spray that looked good enough to me for $5. thank you. I sprayed a little heavy though, oh well.
this week I picked up a pair of 50520's to swap in and I grabbed an upgraded steering tierod set from a dude who has them prebuilt on ebay. My stock ones kept getting loose.
I havent quite looked at how the 50520's attach but I know they should work pretty good. I probably need an extra part or two to attach the top of the shock, guess I'll find out.
oh, and I spray painted those yellow rims black. no more john deer look.
Old 04-28-2012, 01:25 AM
  #7647
giagal
Hi everybody, I'm new in the forum, I've got a LunchBox and read this post full of great hints.
Great job!
Here is a picture of my Lunchie...
Old 04-30-2012, 12:26 PM
  #7648
StevenJV
As I'm sure others already knew, new parts arent necessary to install the 50520's. They went on easy with parts already in the LB kit. I'm using soft in the front and medium in the rears. Soft is way to soft though, going to have to change that out and stiffen it up.
Driving the LB with these upgraded shocks is totally what it needed. Alot more fun. Been putting alot of time on it.
Old 05-01-2012, 05:31 PM
  #7649
tak555
good looking LB, nice italian theme
Old 05-02-2012, 05:33 AM
  #7650
giagal
Thanks tak555,
right now I'm painting another body with another theme, when finished I will post some other pictures.
I will post also pics about hop ups I've done. I'm looking for some simple mod to my Lunchie like installing different monster wheels with hex. Reading on this forum I've understood how to do with the rear axles but I don't know how to do with the front ones.
Anyone can help?
