If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    May 2008
    bellingham, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    tying the streamer
    On our ssc battle axes the line ties on at the base of the rudder. The line runs over the elevator. how much pressure does this put on the elevator? One of the guys lost control and crashed the other day. the mini servo he was using on his elevator was stripped, not sure if it stripped in the crash or I'm thinking it could have been the pressure of the line running over the elevator? ( the rest of us are using metal gear mini seros)
    I'm wondering if it would be better to attach the line to the aluminum rails underneath the elevator as we dont use full down as much???
    Combat is slowing down for me as I am starting to see opportunities to attack. instead of just looping around the combat arena.
    steve
    Excuse me while I touch the sky...
  2. #2
    draftman1's Avatar
    Join Date
    Sep 2007
    Strathmore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: tying the streamer
    metal gear servos are a must, the smaller micros will not handle the stresses. most of us use the hitec 82mg or the gws mighty micro. both are metal gear.
    most of us also have a hole in the rudder for the string. if you have a "battle axe" you will see where it is.
    RCCA #913
    building spads since 12-2007
  3. #3
    GSJames's Avatar
    Join Date
    Nov 2003
    Weatherford, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I agree with Andy. Metal gear servos are a must. I think that it is unlikely that the string on the elevator caused the stripped nylon gear, but any hard landing or even a minor mid air can strip them. I use HS-82MG for elevator and throttle, and HS-85MG for the ailerons. Be sure to use a safety "slip joint" on your throttle linkage to avoid stripping the gears there. The Battle Axe plans show how it's done. Have FUN!
    Gary James
    AMA CD 68845, NMPRA 15I, RCCA #908
  4. #4
    Clean's Avatar
    Join Date
    Apr 2002
    Parkville, MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You know what really scares me. Back in 2002 when I kinda got out of combat because of a layoff I had a whole fleet of A,B,C and Scale ships. With the exception of the C ships most of them had 81's some of those MG's but face it, I had a TON of 81's.
    Of course all of those had centering problems or would just lock over full one way or the other. Luckily, not before my 'Combat Career' ended and usually always on the ground. The thought of a B ship doing 80 mph and going out of control, eash!
    MG servos and pay attention to the loads they will get. Even on metal gears, the first gear off the motor is usually plastic. IF 82's are proven to work go with it. I found that standard servos take the shock a heck of a lot better and aren't that much heavier then a mini with metal gears. But I'm not in serious competition where every ounce counts.
    I could still take your streamer though.
    Intentional landings WITH a PBF are not
    the intentional design OF the PBF
  5. #5
    waynebang's Avatar
    Join Date
    May 2007
    hoschton, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I doubt the string on the elevator caused any problems. The non metal gear servos will work but you will strip a lot of gears in midairs and crashes, I have never had one to fail in flight from air loads. I attach my streamer to the rear of the fin on the Lethal Weapon.
    Wayne
    www.combatplanesrc.com
    Wayne Voyles
    combatplanesrc.com
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
