808 Key chain cam
NJ
808 Key chain cam
This is one of many videos I took using the key chain camera from Turnegy. The quality got better after the microphone broke loose.
http://www.youtube.com/watch?v=rAEOvas_cVA
TX
RE: 808 Key chain cam
how and where did you mount the camera? I put one of these on a 4*40 and the vibrations were so bad the video is pretty much unwatchable, the other problem, which is not as big an issue, is dropped frames, it just looks like it is filming a less than 30fps...but it's okay in that regard. The vibrations make the picture wavy, I see very little of that in your video, are you using a fast memory card maybe? So far I've only tried the cheap ternigy memory card.
Austin
Austin
