Low Heat Covering
NE
Low Heat Covering
Do any of you guys know of some low heat shrink wrap that can be used to cover foam? I know it is going to be a delicate application but can you guys recommend a specific manufacturer or type? As usual, thanks a bunch
RE: Low Heat Covering
Personal preference is EconoKote. TowerKote is brittle and tends to shatter. UltraCote is by far the most expensive of the three but isn't much different than EconoKote.
HTH,
D
HTH,
D
if you can, get solar film.
i don't know if it's still in production but i was covering my eaglet 50 and touched the iron to a piece of blu-cor and it just kinda sat there.
my little iron kinda got stuck but the big one didn't do anything
be careful if you do get it, it's easy to burn
Regards,
Nick
Regards,
Nick
TX
I have used tape, econokote, ultrakote, and occasionally monokote on blue foam. You can use monokote, if the plane is taped beforehand with bidi or strapping tape. Econokote is okay, but it's not very fuel proof. IMHO, Ultrakote is by far the best heatshrink covering for foam, I'm about to try som Black Baron film soon on Ed Kettler's P-70 (A20 night fighter variant)
Cash
Cash
TN
Towerkote is nice because it is Tower Hobbies' re-labeled Econokote, but is $1 per roll cheaper. If you're going to order covering from Tower either way, might as well save a few $.
ORIGINAL: Alex Treneff
Just my experience with the two...
D
TX
Also, I've used a real light covering called Litekote (I think).it's very light, designed for very lightweight e-models, and it works pretty good, as long as you don't let the adhesive side touch itself..then it's like saran wrap, and you'll play merry hobb getting it apart. Takes paint well, though, and goes on at very low heat with good controlled shrinkage, and no tendency to develop wrinkles later on..
Hey Darin, how ya been?
Cash
Cash
TX
Hangar 9 sells a product alongside Ultrakote that is called Easykote. I've used it, it works well, it's a bit lighter than Ultrakote.It's not available in military colors, but they do have a dark green and black. It's on Hangar 9's website, mixed in among the Ultrakote. It's not real cheap, kinda priced in the middle of all the coverings, but I see it on sale once in a while..
ORIGINAL: cashrc
Doin' pretty good here, thanks. Working hard and spending weekends with my kids knocked me almost clean off the Combat Map, but I still keep a close eye on things. [8D]
How's things down your way? Still keeping Ed in line?
D
VA
Ive used econokote on my combat planes great success, and no harm will be done to the foam itself. However with most heatshrink films is that its not all that durable, and by the most part combat is not a gentle sport. I now use good ol' 3m-77 and rip stop nylon. Heavier, but strong as nails.
WA
ORIGINAL: rcfury
Any more input would be apprectated. thanks
Martin
