If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 44
  1. #1
    vertical grimmace's Avatar
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Discontinued .25 FX?
    Does anyone know if OS plans on continuing to manufacture the .25 FX? Tower has them as limited quantities and with the new AX line and particular the .35 coming out, I am a little concerned. This is my favorite engine and if this is the case I nedd to get some more.
    Let's just say, they will be satisfied with less. " Ming the Merciless
    BUSA Bro # 13
  2. #2
    draftman1's Avatar
    Join Date
    Sep 2007
    Strathmore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Discontinued .25 FX?
    yeah me too. nobody knows whats going on yet. that 35 is nice but it wont go into a combat plane that has a 30 max. I hope o.s. will be smart and have an improved 25 to 30 ax. i hope they dont make a 20 to 24 ax, that wouldnt help much unless it had the power of a 25 or larger. I would hate to have to go to a different engine for combat. the o.s.'s just start and run and stay running. I tried the mag 28, I wasnt too impressed. has anybody tried th thundertiger of that size?
    RCCA #913
    building spads since 12-2007
  3. #3
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It seems at this point, if there was something comparable, it would be getting used. I suppose the TT could be promising but I have not run one. I love the .40 and .46 for pylon racing though. The Webra still seems to be the ticket otherwise in combat but nothing is as user friendly as the .25 FX. It will be a sad day when that engine is gone.
    BUSA Bro # 13
  4. #4
    draftman1's Avatar
    Join Date
    Sep 2007
    Strathmore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yeah unless they do make a 25ax. the ax line is really nice and powerfull, I hope O.S. stays smart. I hope the limited quantity thing is just a temp situation. There was a limited supply 3 months back also, then the reg shippment came in.
    RCCA #913
  5. #5
    Join Date
    Nov 2003
    muskegon, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Last I heard.......the 25FX and the 32.are no more! So, if you can find them,....grab all you can!
    I will never understand why OS does this. They have a great engine in the 25 Fx and the 32......why change it or stop making it?? This is not the first time either........they stopped making the 40 SP...and gave us the updated and more powerful 40 LA....WHAT A JOKE!!![:@]
    RC MANIAC-PRO BRO 1900-AMA# 95841
  6. #6
    draftman1's Avatar
    Join Date
    Sep 2007
    Strathmore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    boy that would be stupid, what do they think they are gona do about the 10 to 30 market. that 35 isnt gona be able to do that. in a 30 size yes but in the lower end, no way. I thought the 25 fx was one of there best sellers. who knows. oh well I will just buy another brand if that area isnt being taken care of.
    RCCA #913
  7. #7
    aimmaintenance's Avatar
    Join Date
    Sep 2003
    Montpelier, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I copied this from a thread on RCCA site from last year. It mainly is a discussion about motors for Limited B with a 14500 rpm max but you may get some info out of it.
    I agree with you all that dropping the FX from the line up would be bad though. That is a great running little motor.
    Posted - 04/13/2007 :
    Supertigre .29, Como .29, OS 28F and 28F-H. The OS 28F (especially the heli version) is still widely available in the second hand market, and is a smooth running and very user-friendly engine. With the heli head it is only slightly heavier than an FX, with a standard head it's actually lighter. It has the same mounting and muffler bolt patterns as the FX. Like an FX, it seems to find turning low 14k on the spec prop very routine. Some are higher. As long as you are in the low 14k range you're in the hunt and will be just fine. If you drop below 14 you will start to notice a performance deficit to most of the pack, I think. The ST is a real torquer and may get you over the limit. I used to use STs when the "old" limit of 15.5k was there and they would turn in the 15s easily. Now with the 14.5k limit I don't usually run the STs because I dislike having to shut the carb down, it's easier to just run the FX or 28F. The ST is about the same weight as the 28F and has the same mounting pattern, but has a different muffler spacing (which happens to be the same as the 25FP). All these engines are very durable and have excellent carbs, about the only maintenace item is the rear bearing which is the same size on all of them, and readily available. With the LimB setup it seems that they never wear out or break, unless you eat some dirt (not that that ever happens in combat!).
    As you have observed, the Norvel and FX are good picks. I like the RNV/swept NV on those engines for combat- conventional, straight, carb-mounted NVs have been known to get broken off in midairs and dirt naps. The FX NVA will break off but it's not usually going to stop the engine, unlike a normal carb.
    The Mag 28XL also seems to be a great choice, but be aware that I have seen at least three different carb choke sizes (anywhere from .239 to .270) on the Mag 28. The bigger carb definitely gives more power in a conventional Open B setup, i'm not sure if the smaller carb is a problem for LimB. It might be fine- what size is your carb, and what rpm have you been getting (and with what % nitro?). The Mag 25XL is a bit of a wheezer although it comes with a small carb and performs noticeably stronger with a larger .28 carb (mine turned 14.3 on the spec prop with a bigger carb). The Enya .25X and SS engines are really nice running but only turn about 14k max, which is still pretty adequate but not up there with the FX. They also have weak carb-mounting areas so I would avoid them for combat. I have three, and two have cracked carb mount bosses. They're repaired with JBW and still run great but it's a hassle to break the carb off in a dirt nap! The K&B 28 sportster is kind of weak, only turns upper 13k range. It would get someone in the air if that's what they had laying around, but I'd avoid it if there were other choices.
    The Fox .25BB Schneurle engine has a reputation for being a strong running engine. I have one but have only run it on B props, where it was not up to an FX (and being an iron-piston engine, it is a vibrator at high rpm). I haven't yet tried mine on a LimB prop but based on its performance on a 9x4, at this point i'd say there are better choices. It ran fine for me, though.
    The OS 25 FSR is very weak and I would not recommend it. The 25SF is a nice runner but not as strong as an FX. The Thunder Tiger PRO 25 is a wheezer, weaker than a plain-bearing 25. Any plain-bearing .25 (i.e. OS25FP/LA clone, NOT counting the Norvel) is not up to competitive Limited B demands in box-stock form. I have also run Royal and Leo .28s (basically the same engine), and the Brat .28 and all are rather weak. I mention these because they show up on places like eBay all the time, usually described as "screamers" but as Keith Jones would say, they can't pull the skin off a bowl of rice pudding. And finally, the Webra .25, for all its might in Open B, is a weakling on a stock muffler and limited B prop!
    Hope that helps!
    If it\'s still in one piece means I haven\'t flown it yet.
  8. #8
    draftman1's Avatar
    Join Date
    Sep 2007
    Strathmore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks for the info. im still confident that os will have a 20 something they will bring out, an improved model. an official notice from os about a discountuance of the 25 fx and its replacement should be in order. the best thing we could do is e-mail o.s. to there "make a sugestion" place and let them know that we need a engine in that range.
    RCCA #913
  9. #9
    Join Date
    Sep 2007
    WymondhamNorfolk, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: draftman1
    I had a thundertiger max 25 in my gremlin. absolute nightmare. difficult to start, and between us me and my father have never had trouble starting engines in 30 years experience.
    plus in it's 5th flight the silencer broke. I gave up on it and put an OS25 FX in. Never going back! absolutely beautiful engine, starts first or second flick and is powerful and reliable. Will have to buy a couple more of these before they disappear.
  10. #10
    Join Date
    Nov 2005
    Somwhere, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So what is the conclusion? Is OS discontinuing the 25fx or not. If that is the case, I dont know how I am going to continue with combat
  11. #11
    draftman1's Avatar
    Join Date
    Sep 2007
    Strathmore, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I got a reply from Bax, the Hobico Guy, He said there not discontining the 25fx, the mew 35 os to replace the 32. great news!!!!
    RCCA #913
  12. #12
    Join Date
    Nov 2005
    Somwhere, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good deal, glad to hear it. I just bought a new one a couple months ago I and I was afraid I was gonna have to go back and buy out the store. I love the OS 25fx
  13. #13
    Join Date
    Dec 2004
    hastings, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi all
    I have had to give up combat do to arthritis in my thumbs and if any one is looking for a 25fx that was mounted and never ran. pm me and I will give you the the info
    cheers Bob T
  14. #14
    Join Date
    Feb 2007
    Bishop\'s StortfordHerts, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Have just started combat in UK on an occasional basis.
    Was advised to try the ASP.25 if on a budget as an alternative to the more expensive engines. Got "two for a deal" on special offer. On APC 9x4 and 10% fuel, quite good. On Coolpower 30, got another 1000rpm's though ran a bit hot. Have used them now twice in Gremlin Combat sessions and they kept up with the best anyone else had! Only thing I did was use two plug washers & set the HS slightly rich on the ground. 5 mins runs at full throttle in 29deg C temps, consistent running and easy starting even when stinking hot. (standard mufflers, APC 9.4x4.5)
    My two pence/ cents worth!
    Bill.
  15. #15
    Join Date
    Nov 2002
    Manitou Springs, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bill, what kind of rpms were you getting out of the ASP?
    r
    Randy Hodges
    RCCA 745
  16. #16
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Randy. Didn't record it but will try get a reading soon & post here. All I can say is that my Gremlin went as well as anyone elses and better than several, with different engines, eg OS FX, ASP, Irvine and yes close to a West .25 even! On standard 10% fuel I'd have been a bit down but the engine still goes well on 10%.
  17. #17
    Join Date
    May 2003
    Blackfoot, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RH, I have an ASP .25 that run's 17,800 on a MA S2 9 X 4, Sig 15% fuel, mousse can. I think it is a one in a million though.
    Randy Shiosaki
  18. #18
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: yankee samurai
    And those are really not very good numbers. The FX gets close to 20,00 with that setup.
    BUSA Bro # 13
  19. #19
    Join Date
    Feb 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi again Randy. Flew my ASP again yesterday on Wildcat 30%. In cool temps (about 8deg C) I got 13950 on a normal APC 9x4. While it might not sound hugely spectacular, remember, this is on a bog-standard muffler (small volume & outlet!) and standard ASP carb. (not allowed mousse-cans or other tuned systems) I'd also venture that at that rpm's the engine will last awhile, unlike at 18-20K! For me it works well and the engine handles well outta the box and completely standard. (just using 2 plug washers)
    Anyways, I'm only limited by ability and luck, not performance, so that suits me fine!
    Regds, Bill.
  20. #20
    Join Date
    Nov 2002
    Manitou Springs, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Bill, appreciate the info.
    r
    Randy Hodges
    RCCA 745
  21. #21
    Join Date
    Feb 2006
    Lima, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum may come out with an XLS. If it performs like the 15xls we have a good replacement. Hopfully Magnum will keep the displacement at .30 or below and use a remote needle valve to prevent damage in combat.
  22. #22
    Join Date
    Sep 2007
    american falls, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    how close is close? it's kind of relitive
  23. #23
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well let's see. It has happened. The new one is very expensive. Not active with combat anymore but this was one of my all time favorite engines. Hopefully the new one will have even more power.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXXEG2&P=7
    http://www3.towerhobbies.com/cgi-bin...&I=LXBY42&P=ML
    BUSA Bro # 13
  24. #24
    oceansfiftyseven's Avatar
    Join Date
    Sep 2004
    Shoreline, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So the new version is 20% heavier and 50% more expensive. Ouch!
  25. #25
    Join Date
    Mar 2004
    ft collins , CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Not only will it screw your balance but also your pocketbook. I wonder if it will be more powerful though? My .46 AX is much better than my .46 FX. Anyone have experience with the .35 AX?
    Oh, but I guess at this point, there is no search for more power.
    BUSA Bro # 13
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
