Buried it and broke my needles valve
MA
Cleaned outr the engine and its running fine but the needle valve is now just hanging there.. I was thinking of epoxying it back in place...
What are my other options?
Steve
Steve
MI
RE: Buried it and broke my needles valve
Wrap a zip tie around it then trim it off leaving a 1/2" end. Then shoot a small screw thru it into your motor mount. Works great.
Rick
Rick
They almost ALWAYS break off. As long as the backplate is still sealed correctly, you can attach it using a zip-tie and a piece of fuel tubing. I'm not sure if this photo will come out clearly enough, but look at how the needle valve is NOT even attached to the engine. This airplane is by a perennial #1 NPS place holder, Evan Wenger, so you KNOW it works.
CA
Im with Gary, most of my combat ships have the valves broke off, no reason to worry about it. I won first in opne B last weekend with it like that
MA
ORIGINAL: Rflyin
Wrap a zip tie around it then trim it off leaving a 1/2'' end. Then shoot a small screw thru it into your motor mount. Works great.
Rick
Rick
Or put clamps on the hoses,
Steve
Out of the 7 I have at least 5 are zip tied. Fox makes a nice cheap remote needle valve with a screw in bracket. If you really want a solid fix order one, i have a couple around ive been trying and they work fine, just about double the weight though...
NY
On my Hell on Rails I used the OS remote needle valve kit and mounted the needle valve on the fuselage rail behind the engine.
