RC Drag Racing For all you straight line enthusiasts. Discuss all aspects of rc drag racing here!
2wd vs 4wd - which is better?
Reply
Old 02-12-2016, 12:53 AM
m1tch_87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 2wd vs 4wd - which is better?
Hi all,
Just a quick question, for speed runs would it be better to run 2wd or 4wd, I can see that the 4wd system would have more drivetrain loss, however 2wd would have 50% of the grip as only 2 wheels would be powered.
Just wondering which people find to be best, I am guessing a 2wd setup for speed runs eg rwd only due to the fact that the engine can spin up easier and there is less driveline loss overall.
m1tch_87 is offline
Old 02-12-2016, 07:25 PM
Maj_Overdrive
Maj_Overdrive's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Are we talking outright top speed runs or drag racing to a finish line because this is the drag racing section? For drag racing the answer is it depends on the vehicle. Purpose built drag racers are 2wd but they're feather weight and built to maximize the 2wd. If you're adapting an existing vehicle then 4wd is probably better.
For top speed runs it's basically the opposite. In theory a vehicle with less drivetrain loss should end up going faster. But in reality there are other factors that come into play. The biggest of which is limited distance (both space and sight distance) to get up to top speed. Limit traction and you limit the amount of acceleration in your limited space to get to top speed. Not to mention your overpowered vehicle is harder to control with less traction.
The only time 2wd is going to be an advantage is when you artificially try to limit the vehicle instead of going all out. An example would be trying to have the fastest 2s vehicle. 2s doesn't need as much space to reach top speed so drivetrain losses and aerodynamics play a bigger part of the equation than the space needed to get there. For 2s a 1/10 buggy or touring car make the most sense and will get to top speed easily. But put those vehicles on 4s and you're going to need a bunch more room since the vehicle will be overpowered and you won't be able to just mash it. Have a look at the fastest rc cars, the ones going 100+, they're all 4wd.
Maj_Overdrive is offline
Old 02-13-2016, 06:06 AM
m1tch_87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info, I will keep the car 4WD then - going for ROSSA records so I figured that the drag section would be the best to post in, I wasn't sure which one would win out against the additional traction and the driveline losses - need to get the power down to accelerate so 4wd it is!
m1tch_87 is offline
