RC Drifting Discuss all aspects of rc drifting here!
Need help with Electronics
Reply
Old 10-10-2019, 07:44 AM
samx6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need help with Electronics
I am very new to this hobby and I am setting up my first drift car and would like some advice.
I plan on running a 120Amp Hobbywing Esc and Motor. I want to get a 2S 5000mah Lipo, but I am unsure what C rating to get.
The ESC has a continuous draw of 120A and Burst of 760A. I know a 25c would work for the continuous draw, but I am concerned about the burst.
Here's my math(could be wrong):
120A / 5A(5000mah) = 24, thus the 25c should be fine.
760A / 5A(5000mah) = 152, thus greatly straining the battery.
Would it be better to go with a lower Amp ESC, such as 60?
Thanks!
samx6 is offline
Old 10-11-2019, 05:36 AM
bill_delong
bill_delong's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You're on the right track, but need to be comparing everything to power draw or Watts in order to get your burst ratings.
You didn't specify which motor you plan to use, and that will be the first step.
For example, let's just say that you are planning to use the XERun Bandit 10.5T motor, you will want to click on the "Specification" tab and you will see that "Max. Output Power* (W)" = 325W for this particular motor. No problem if you decided to go with a different motor, just want to explain how the math works in general for you.
Now that you know the motor can pull up to 325W, you simply multiply the C rating times capacity of your battery time voltage of the pack:
25C x 5Ah x 8.4V = 1,050W
As you can see, the 25C pack is no where near the limit of power draw for the motor I referenced making the 25C pack perfectly acceptable for use with that motor.
bill_delong is offline
Old 10-11-2019, 11:52 AM
samx6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, so I just looked a the specs on the Hobbywing Quicrun 3650 and it has a max of 240W, so 7.4V x 5Ah x 25c = 925W. I should be fine correct?
Also I have another question, The math that I did in the original post has nothing to do with it then? I thought I had to figure out the power draw of the ESC as well?
I plan on using the Quicrun 10BL120 ESC.
Sorry if this is a dumb question. I am very new to this.
Thank you!
samx6 is offline
Old 10-11-2019, 12:03 PM
bill_delong
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A fully charged 2S LiPo is 8.4V which is what I like to use for my calculations, but 7.4V nominal is also perfectly acceptable too, we are calculating "ball park" estimates anyway.
You can use Ohms Law to figure out how many Amps your ESC needs to be:
Watts = Volts x Amps
240W = 8.4V x Amps
240V / 8.4V = 28.57A
Any ESC rated 30A or higher will suit your needs just fine
Old 10-11-2019, 12:35 PM
samx6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for all your help! I appreciate it!
samx6 is offline
