What should I try to get better drifts?
I finally got my Yokomo MR4TC Special drifting, I just wrapped some old tires with some electrical tape and tried drifting on several surfaces, the best surface I used to get good drifts on was at a car wash parking lot, it pretty slippery, ran several packs and was getting some pretty nice drifts outta there, what else can I do to get better drifts out of the car? Im thinking of trying those Yokomo Drift tires, also what about the setup on the car? should I soften, or harden up the suspension? and ride height? lower or higher? how about a roll bar? im going to try some of these settings, hopefully it helps in drifting
RE: What should I try to get better drifts?
50mm PVC polypipe dude, then Drifting will be soooo easy you'll have a grin from ear to ear
If you go PVC pipe, use soft front springs/slightly harder rear springs, oil isn't that critical for Drifting, and depending on the smoothness of the surface your Drifting on run between 4-7mm ground clearance
Oh yeah, 27T stock motor is the hot ticket
Yeah, i know nothing about drifting so i need to know this stuff too. the best way i can drift is on a glossy cement or tile but usually its too slippery. apparently on Need for speed underground, to get better drifts, u need to downgrade stuff. so is it true with R/C cars that have most things stock helps with drifting?
RC Drifting is low cost, high fun, low tech, high fun, low maintenance, high fun, high runtime, and did I say high fun?
www.rc-drift.com for more answers
