argggg....how do i get them off
RE: argggg....how do i get them off
umm set it up so u have something under the PVC pipe alone and hit the rim (just dont break it) and the PVC should come off
[))] [ ] = PVC pipe
l l l l = stand
)) = rim under PVC
[))] [ ] = PVC pipe
l l l l = stand
)) = rim under PVC
My Feedback: (7)
NV
try boiling the rims. that will loosen the glue but if its pressure fited them man i don't what to do just go and buy the cheapest rims you can find
My Feedback: (7)
NV
ohh uhh umm, I GOT IT GET A SKIL SAW AND PUT THE RIM IN A VISE OR SOMETHING OF THE SAME IDEA AND VERY CARFULLY AND SLOWLY CUT THREW THEN WHEN YOU GET CLOSE TO CUTTING THE RIM I GUESS JUST USE A HOBBY KNIFE TO DO THE LAST
IL
If you use them to the point where they are very very thin you can just rip them off by hand. For the abs that is. The pvc may be a different story i suppose.
I would put it on (not in) a vice so that only the pvc/abs is on the edge and then gently hammer the rim down (out). The saw idea sounds good too. or drill a hole in the middle and use a needle nose pliers to rip them off.
