is the tamiya tt-01 right for me??
BC, CANADA
ok well i am willing to spend around 200$ on a car i have the servo and the reciver and all those goodies but i need an esc and a motor i am thinking of getting like a 13-17 turn motor would this be smart for driting? and i dont know what tires i should get, i heard that abs were good but they seem expensive, any tricks on usefull info would be very nice thank you
RE: is the tamiya tt-01 right for me??
Get at least a 19t. Those motors you have listed will kill your runtime, and not have enough torque. ABS id not expensive AT ALL. How does 15 bucks for 2 sets cost.
i just bought one of the 2inch dia 10feet pipes
and a pipe cutter
the total came to about 25 dollars at homedepot
all i need is someone to hold the pipe while i cut it
lol
and a pipe cutter
lol
i have an idea... can you 'true' your abs pipe tyres after youve stuck them on, by holding one wheel still, giving power to the car, then push the spinning wheel onto a file to grind it down into shape....
BC, CANADA
wow, rhank you for the comments they are quite usfull. i got another question.. does the tt-01 come with a 27turn stock? and how fats is it top speed like 15mhp?(with stock motor)
Yeh m8 stock 27 silver can motor and a tamiya ESC usually(can run down to 21t safely)
about 15mph as stocker,add some metal bearings to your ride,add a 21t motor and the ali prop shaft and you should be hitting 25+mph [8D]
ORIGINAL: DANDthekid
For a good motor, go with Yokomo, get a drift motor, they work great
BC, CANADA
hmmm i was looking at the venom fireball 21t motor should this do or should i got for a high end ?? go on ebay type in fireball motor and it will be the 21 turn .i need our help guys!
BC, CANADA
oh and another thing is i am replacing the esc lol and i would also like some suggestions for that:P
NV
I am going with a DuraTrax Sprint ESC ($30) and Orion Method R 19T ($22 if Tower gets them in) + Robinson Racing Metric Pinion Gear 22T to go with Stock Spur.
I am hoping this is the best setup for balanced drifting/power/run-time/$
(I am also hoping this setup would finally out-run my Hornet with the TEU-101BK + Method R 21T while drifting on ABS )
My TT-01 is running great with no huge electronic hop-ups. I mean to drift you dont need anything special... I threw on some ABS tires with my Stock Silver can motor and I was drifting like a pro haha... well maybe not a pro but its anough to let me drift around any thing I really want.
Just upgraded to the Tamiya Sports Tuned engine thats probobly the most I'll need.
Sell the stock esc and motor that comes with the kit on ebay then go out and buy a Dynamite Tazer ESC for $30 and a 19turn motor (checkpoint money or komodo drifts really nice). if you're on a budget, get the orion Method R 19 turn motor.
ABS tires are fairly inexpensive compared to the "drift tires" that are made by rc companies.
ORIGINAL: pimpedarse
BC, CANADA
umm i would also like to know what spur gear i should get.. or are the stock ones good for drifting?
NV
ORIGINAL: GTB
You don't have to get a ''drift motor'' to drift good. I run a Tamiya Superstock TZ, it not a ''drift motor'', but it does the job.
