Anyone looking into getting into r/c drift read this!!!!!
CO
Ok here is what you need to drift. This is for anyone. A 4wd chassis. People are gonna say 2wd which is possible but it is very difficult. Hard compound tires made by HPI, YOKOMO, and TAMIYA. People also use PVC or ABS which is a type of pipe that you can find at your local hardware store. You are gonna need 2 inch. That's the basics. Set up wise you are gonna want a hard spring rate in the rear and a soft one up front. In other words hard springs in the rear and soft in the front. Some people like to run locked rear diffs. In my experience it's not needed. There are various ways to do this. For a couple examples I've heard is super glue, silly putty, or fuel tubing. There are write ups just search for them. Some people also lock up the front. But this will hurt your turning greatly. Ok lets see motor wise you want I would say anything between a 27-15 turn. Another thing is upgrade to ball bearings if your car didn't already come with them. I'm also gonna start a new post and so maybe people will see it and not have to ask and wait for responses. Anyone feel free to add to the list. Maybe a mod could make this sticky?
BC, CANADA
RE: Anyone looking into getting into r/c drift read this!!!!!
there already is a thread like this, check it out http://www.rcuniverse.com/forum/m_1942492/tm.htm
plus its already stickied
CO
Yeah but this all in one post oh well lol. Nm then. Still hope this helps someone out.
ORIGINAL: em x 6 racer
also, why did you repeat yourself with the spring setup section?
It may help, but at the moment it's not very well organised...
CO
UMMM bud look at a couple posts here. And i put that so People who didnt know what spring rate was could understand. And if you look it says "in other words". I was trying to help but hey forget it.
This is about rc not correcting people
ORIGINAL: wst50
No-one says use 2wd, it's practically universal law in RC drift...
AB, CANADA
people ask the same questions over and over, what should i get, what is the best drift car, they should read one of these posts.
AB, CANADA
ok i have a question i have a novak brushless systen is it a good idea to use in a drifter??
Banned
CA
ORIGINAL: GT RACERMAN
Brushless motors are not he best for driftng, as they have way too high rpms and less torque. For drifting torque should be more important than speed.
LA
yeah i have the 5800 and a and the 6 progran super sport esc i had it in a duratrax evader it was clocked at 44mph on 2500mah batts will it fit in a car? is that good enough?
WI
say i was to by a tt-01 kit and do everything you said up at the top. would that get me drifting good?
