any seen or have the new team orion drift motors
MD
I just ordered one of the new team orion drift motors any one else have one or heard about them .
What do you think ? here are the specs
ORI23411
Armature: Stage 1, 4mm Machine
Wind: 18x3
RPM: 26,650+
Power: 133.9W+
Endbell: TOP V2 adjustable timing
Can: TOP Chrome w/ G13 Mags
ORI23411
Wind: 18x3
RPM: 26,650+
Power: 133.9W+
Banned
RE: any seen or have the new team orion drift motors
The x3 Windings Would mean that a ESC that has a 15T limit would be needed to account for Current Draw and Torque Load it could put out..
I have to agree with Spartan though, the Method R's are way sufficient for Drifting as they are a x2 Wind motor..
MD
are you running the method R motor.? if so have you been happy with it and are you use drift tires . I got the new hpi sprint 2 and im running drift tires had a hpi pro 4 with a 8.5 turn brushless but it's way to much speed and power for drifting . my new car has a 17x2 brushed motor but it's got bushings not bearing and heats up way to fast
Banned
I use the Team Orion Method R 15x2T for High Speed Drift on Polypipe.. on my Sprint 2.
Now the 15x2T is Great for 30kph + High Speed Broad Drifts but it is getting a little too low for Technical Drift..
When I Switch it over to rubber Thats when the Fun Begins... It then Shows th True performance of a 30.000rpm motor...
I Still use the LRP GT3 Turbo 17x2T motor on my Sprint 2 for Drift as it has plenty of Torque needed to slide..
I Just Ditched the AI ESC for a Proper No limit with Reverse...
